Brake bleeding on a 98 ?
Old Sep 10, 2002 | 10:09 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Brake bleeding on a 98 ?
Bear with me as we just got a 98 and the brake fluid is filthy.(40,000 miles on what appears to be the original fluid) I want to drain and replace the fluid but I don't want to screw up the ABS.
Old Sep 10, 2002 | 11:09 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: Brake bleeding on a 98 ? (Mark 84ltblu)
bleed as normal but don't let the resevoir run dry
Old Sep 10, 2002 | 12:46 PM
gmblack3's Avatar
gmblack3
Default Re: Brake bleeding on a 98 ? (MRWHOOPPEE)
I would call the dealer and see what they want to do the flush with the Tech 2. This will get all the old fluid out of the ABS system. If you are going to keep the car for a long time I would do this. If only for 3-4 years then just flush it yourself.
Remove all the fluid you can out of the reservior with a turkey baster and then fill the reservior with fresh fluid, then do the flush.
If the car is a 6 speed also remove all the fluid out of the clutch reservior and wipe out the inside with a paper towel. then refill with brake fluid.
Old Sep 10, 2002 | 02:09 PM
Mark 84ltblu
Curise-In V Veteran
Thanks! We tend to keep cars for 6-7 years so I'll let the dealer flush the entire system.
:seeya
Old Sep 10, 2002 | 02:34 PM
VetteDrmr's Avatar
VetteDrmr
One thing to think about is why your fluid got dirty in the first place. It's due to water absorbtion, mainly. Folks racing their cars will flush out their fluids multiple times a season, but even non-racers need to get their system flushed every 2-3 years. Also, the ABS system will get almost all of it flushed out normally. If you're really worried about the fluid in the ABS, then go out and get on the brakes hard enough to activate the ABS; that'll move some fluid around! :D
Seriously, though, don't wait another 4-5 years to flush it out again.
Have a good one,
Mike
Old Sep 10, 2002 | 04:20 PM
Mark 84ltblu
Curise-In V Veteran
Default Re: Brake bleeding on a 98 ? (VetteDrmr)
Thanks, Mike. We just got the car last week and the previous owner was not as careful about some of these things as I am.
To Brake bleeding on a 98 ?
