C6 shifter upgdae
Old Jul 5, 2016 | 02:18 PM
Harold97's Avatar
Harold97
Default C6 shifter upgdae
I'm planning on installing a C6 Z06 shifther in my C5 any thoughts or suggestion
Old Jul 5, 2016 | 02:56 PM
Macleod52's Avatar
Macleod52
Search the forums. There have been hundreds of people who have done this mod. Plenty of info out there with just a little effort.
Old Jul 5, 2016 | 03:49 PM
73Corvette's Avatar
73Corvette
It's a plug and play... remove the old shifter and box... put the C6 one in it's place...
But, make sure your C6 shifter is really clean and lubed... that the bushing that keeps crap out of the box is not cracked or split...
Make sure your neutral pin is in and when you tighten the clamp on the shift rod get it tight but DON'T strip it out or break it off...just be careful and take your time...
You should take it for a spin before putting everything back together... you may have to make some adjustments...
Old Jul 5, 2016 | 08:20 PM
Paul 75 L82's Avatar
Paul 75 L82
I love mine,
Old Jul 6, 2016 | 01:26 AM
Mickeyrx70's Avatar
Mickeyrx70
________
I did the mod a couple of weeks ago. I used the TPS 427x C6 Z06 shifter with one of the shifter grips they offer -- I like the looks and the feel of the shifter ****, but I couldn't really tell any difference at all in the actual shifting. I might try the MGW shifter next.
Old Jul 6, 2016 | 07:25 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by 73Corvette
Make sure your neutral pin is in and when you tighten the clamp on the shift rod get it tight but DON'T strip it out or break it off...just be careful and take your time.............
HIGHLY recommend using torque wrench to spec of 22 lbft. Do NOT overtorque, it's easy to do.
AAMOF, all three T-40 Torx bolts are 22 lbft.
HTH
To C6 shifter upgdae
