Help, can't find temp sensor
Old Sep 10, 2002 | 04:52 PM
bob98's Avatar
bob98
Default Help, can't find temp sensor
I want to replace the ambient temp sensor (outside air), my service manual shows in on the upper right radiator mount--I can't see it there. The dealer parts breakout shows it on the cowl, passenger side. Before I remove anything there, I would appreciate any insight on its location and what has to be taken off to get to it
Old Sep 10, 2002 | 05:13 PM
C5Cemo's Avatar
C5Cemo
Default Re: Help, can't find temp sensor (bob98)
you can see it from the underside of the nose on the passenger side of the shroud. It's small and black about 2 inches from the bottom.
:cheers:
Old Sep 10, 2002 | 05:20 PM
allanlaw's Avatar
allanlaw
Default Re: Help, can't find temp sensor (C5Cemo)
It comes in from the side, in between the shroud and the radiator.
Old Sep 10, 2002 | 05:23 PM
scool93535's Avatar
scool93535
What they said above, it plugs into the wiring harness inside the right side close out panel. If I remember correctly there will be one hold down at the temp sensor to open. :seeya
Old Sep 10, 2002 | 09:32 PM
bob98's Avatar
bob98
Thanks folks! I believe I see it, I did not expect it to be that low--need to have the car cool though
To Help, can't find temp sensor
