I installed a dual catch can setup and removed the PCV. Drove the car about 100 miles and checked the cans. The can between the lower intake and throttle body had about 3 tablespoons of oil, seems like alot.
Has anyone run this setup? Did you run the PCV? If so, what's the easiest way to run a PCV inline?
Thx,
Mike
Not sure why you'd completely remove the pcv? You're basically allowing the car to pull suction through the catch cans and on the valve covers.
I redid mine to alleviate the same issue on my ls1
Are LS1 and LS6 setup differently? I have 2 circuits
** Lower intake manifold to aft of throttle body, PCV in between
** Pass. valve cover to aft of throttle body, no PCV
Thr ls1 does have a different set up, however you still should have the pcv valve in place to restrict the amount of vacuum being pulled on the valley pan line to the tb. There is still oil mist contained within the vapors of the crankcase. Installing an orifice style pcv inline before your catch can should cut back on the oil you collect in the catch can.
Reason: Spelling
The line on the passenger side valve cover is your "air in" and the line on the valley cover is your "air out". Just an FYI. That's why the pcv valve is on your valley cover line, to restrict the amount of circulation within the crankcase and cut down on the oil mist being drawn into the intake, or in your case the catch can.
I still have the parts, I'll install the pcv and recheck the system.
