LS3 in a C5?
Popular Reply
LS3 Crate Engine
LS2 Throttle Body (LS3 won't work)
Clutch/flywheel/Throwout Bearing of your choice (might as well do it while you have engine out)
Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module
Racetronix LS2 Throttle body adapter harness (PN LS2-TBAH).
GM MAP Sensor 24" Adapter Harness- Connects LS1/LS6/LS2 to LS3/LS7 Style Sensor (Ebay)
Set of 8 - EV1(Jetronic) to EV6/EV14/(USCAR) Fuel Injector Adapters (Ebay)
Knock Sensor extension/conversion for 2 wire knock sensors
Larger Radiator (not sure if you need it but I race and I run too hot with LS6 and stock radiator
Engine Dyno Tune (don't start it with stock tune, run risk of running very rich and rinsing rings since injectors are larger)
Fluids
It adds up quick, going to be in the 10-12K range depending upon choices (engine, flywheel, radiator, etc), however you can offload your LS6 for $3000+ if mileage is lowish. There is an article in superchevy, pretty good, but they build LS3 from scratch and don't need all the same cables/electronics.
Stuff you will transplant is:
Bellhousing
Front end drive accessories
exhausts/headers
batwing oil pan (with dipstick and oil pickup) be careful here the ls3 oil pump pickup bore is slightly larger you need to buy/use red o-ring
engine mounts
swap oil pressure sensor (LS3 has different connector and I could not find a harness)
cut off one unnecessary block bolt hole ear that interferes with passenger side engine mount bracket
etc....
And biggest of all,...., dont stress trying to get oil pressure with just cranking before or after you install the engine, I spend 2-3 days on this taking pans on/off, checking oil pickup height, checking orings, stressing, stressing, no psi!!!. The engine crank speed (10 rpm/min?) is not enough to build pressure. The motor already has oil primed through by factory. Just put it in and fire it up (after tune as mentioned above). Oil pressure comes on immediately when the engine fires and gets up above 500 rpm..!!!
Its quite a bit of work, not for the faint hearted. I have a 38" rise lift and cherry picker, held engine up, dropped cradle onto a 500# harbor freight table jack, lifted engine out from top, was not bad at all.
LS3 Crate Engine
Fluids
Bellhousing
exhausts/headers
engine mounts
etc....
Similar to Garry, but I am going the more custom route. The engine is a 427 LS3 from Hinson Motorsports.. have a laundry list of mods going on with the engine... including T6060/C6 Diff.
As Garry said, you will need a few cables / harnesses / etc. One thing to note - if you have the block custom build, you can have a 24x reluctor wheel placed on and not need the LFE conversion box.
Here is a snap shot of what I bought so far.... includes engine build with HINSON, and a lot of accessory parts. I plan on sending my PCM to ECS for a starter tune so I can bed the clutch before taking it the dyno for complete tuning. My place doesn't have the space to do the swap, so I am paying a local mechanic to do it all... quote is approx $4k for engine/trans/diff removal and install of new parts.
Engine
$1,677.22 HINSON GM Block LS3/L92
$115.69 HINSON GM Oil Pump LSx VVT
$245.69 HINSON ARP Main Stud Kit LS1/LS2/LS3/LS7
$859.00 HINSON K1 Technology 4340 Forged LS1 Crankshaft 4.125' 24x
$575.00 HINSON K1 Technology H-Beam Billet LS1 Connecting Rods 6.125', Stroker
$776.34 HINSON Diamond Piston - 4.065", 4" Stroke, 6.125" Rod, DISH (12deg L92 Pockets)
$19.99 HINSON GM LS 24x Reluctor Wheel
$1,095.00 HINSON "Labor -
* Bottom end Assembly
* Machining Service
* Reluctor Wheel Change"
$368 HINSON Labor -
* Install & Pin crankshaft balancer > ARP bolt.. dont go OEM
* Install Clutch
* Install intake, fuel rails, and injectors
$113.95 HINSON ARP Hex Head Bolt Kit LS2/LS3/LS7 >> Went with STUD kit instead
$77.00 HINSON GM MLS Head Gaskets 6.2 LS3/L92
$2,449.00 HINSON Trickflow 255cc CNC Ported Cylinder Heads LS3, Steel Retainers, 465 lb Valve Springs
$534.00 HINSON Yella Terra Ultralite Rockers LS3/L92, 1.7 Ratio Non-Adjustable
$399.00 HINSON Custom Grind Bullet Camshaft
$108.43 HINSON Comp Cams 5/16' Magnum Chromoly Pushrods 7.450'
$20.61 HINSON GM Front Main Seal LS1/LS2/LS3/LS7
HINSON GM Front Timing Cover Gasket LS
$5.50 HINSON GM LSX Crank Bolt
$111.41 HINSON JP Timing Set Single Roller LS1
$236.91 HINSON Comp Cams Front Timing Cover LS1/LS2/LS3
$199.99 HINSON Powerbond 25% Underdrive Pulley, 97-13 C5/C6, 08-09 G8 GT, 09 GXP, Chevy SS
$936.00 HINSON McLeod RXT Street Twin Disc Clutch (LS1-LS7)
$289.00 HINSON McLeod Steel Billet Flywheel (LS1-LS7)
$73.62 HINSON GM Rear Cover - LS1
$24.28 HINSON GM Rear Main Seal LS1
$205.44 HINSON Walbro Corvette 255lph 97-03 C5 Fuel Pump
$489.00 HINSON DeatschWerks 60lb LS1 Injectors
$137.95 HINSON Holley Billet Fuel Rail Kit LS1/LS2/LS3
$300.00 HINSON LS3 Intake
$390.00 HINSON LS2 TB
$151.00 HINSON LS7 Water Pump
$642.00 HINSON Halltech CAI w/ LS7 MAF
$900.00 HINSON Hinson 1 7/8 ceramic coated Headers / X pipe
$43.85 Ticks Pilot Bushing & GM Bigger Bearing (Dep on what mechanic recommends)
$54.95 Casper Caspers Knock Sensor & Cam Sensor Adapter Harness 109081
$37.73 GM LS3 Crankshaft Position Sensor 12585546
$33.95 Casper LS1 MAP Extension 26' 109080
$63.60 Casper 8 x Injector Adapter EV6 to EV1 109077
$35.63 Amazon Oil Pan Gasket
$250.00 Hinson Hinson Urthene Engine Mounts (with heat shields)
$142.99 Ticks Performance Slave Cylinder & Throwout Bearing
Total
$15200~ > my original goal was 10k for engine and parts.
Some supporting mods I already have on the car... I wouldn't toss a LS3 into a C5 without having a few in place ( again, as Garry suggested - Radiator is a good one to do)
Billyboat Exhaust Tips
Ticks Adjustable Master Cylinder
R1 Concepts Front Rotors/Pads (slot/drilled)
DeWitts Radiator w/ Oil cooler
Elite Engineering Oil Catch Can
Hurst Shifter + Moto ****
Hotchkis Sway Bars
Stance SS/GR2+ Coilovers
CCW 505A's 18x9.5F/ 19x11R
Elite Engineering Tunnel Brace 1/4th (thermal)
Bump Steer Kit Front/Rear
RKT T6060 / C6 Diff/Trans/TT Upgrade > to be installed
ECS Brace >to be installed
Drive Shaft DSS 3.5" >to be installed
SFK Wheel Bearings
Wheel Bearing Fastener Kit (If you change wheels bearings I HIGHLY RECOMMEND)
Sorry for the long *** lists. Trying to give you an idea of what to expect before you dive into it... make sure you know what your goals are, like HP and budget.
I bounced around from wanting a 1000HP build, and that is why I bought the rear end from RKT. My engine won't be near that, but if I decide to go FI - I will need to remove the heads / change the CR on the engine for best boost and such. that is for another time.
Good luck... if you have any q's.. pm me...
on 100LL through a 6 Speed Manual. Ebay Headers Open Cutouts. Factory Mufflers
540rwhp 490 RWTQ
