P1870
First the car is an '01 A4 with 22K on it. Before engine and trans reach operating temps lockup works as designed then after a 30 plus mile Hiway drive in which the converter will unlock sometime during the drive the car will throw the P1870, and max out line pressure which results in very harsh 1-2 shifts. Let the car cool down for around 30 minutes and all is good until the return trip and the same issue replays itself. Research seems to point towards a very common sticking TCC valve or a worn TCC bore. However the worn bore is most common on much higher mileage cars.
So before condemning the valve, solenoid or blaming the recent tune we did some testing on the road and found this during a Hiway test drive; when the converter unlocks, which you can feel, hear and see on the tach we pulled the codes and there was a current P1870. We cleared it and within 2-5 seconds the converter locked up. Shortly after, while going up a grade the converter unlocked as it should but didn't lock back up at the crest or down grade. Pulled codes and the P1870 returned. Cleared it and the converter locked. Did this several more times during the drive. Last time it unlocked we left it that way and exited the Hiway. At the stop we pulled the codes to see if P1870 returned and it had. We cleared it and took off from a stop. Half expecting the 1-2 shift to be harsh we were somewhat surprised it was all normal, without any cool down period.
So at this point I'm not sure what to blame for the malfunction. If the TCC valve was sticking or had a worn bore, clearing P1870 thus resulting in the PCM recommending lockup shouldn't work, but it does. Next I would suspect the PWM solenoid but if it was faulty why would it function correctly after clearing P1870 again causing the PCM to recommend lockup and have it work each and every time. I will add that the unlock condition only occurred during loading the car such as a hill or accelerating to pass but was somewhat intermittent. It would unlock/re lock 2 or 3 times in a row then unlock and not re lock until we cleared the P1870.
The TCC valve and solenoid are not pricey parts and the job is easy but we don't want to throw parts at it if they are not the cause. Kind of out of ideas at this point. Don't know if anyone has experienced the same issues but would appreciate any input.
Sorry for the long read. At least I used paragraphs.
Other than that, a sticky tcc solenoid maybe. But cjearing code, it should come right back.
A couple things you can do:
- increase the PWM duty cycle in the computer tune
- in the computer tune have the converter unlock with less throttle for given speeds so that it doesn't see the higher than stock torque for a given speed/rpm
Thanks!
