PCV install help
Old Jul 28, 2016 | 03:55 PM
lusor's Avatar
lusor
Default PCV install help
I want to build a homemade PCV system to get rid of the stock pipping.The plastic boot that holds the PCV is destroyed.My problem is one side of the valve is a normal 3/8 fitting but how do I connect the other side ?
Old Jul 29, 2016 | 10:52 AM
SaberD's Avatar
SaberD
I would suggest picking a new boot up from a junk yard. Most modern 5.3L GM truck engines use the same size pcv valve and boot, so it should be easy to find.
Old Jul 29, 2016 | 05:01 PM
heavyzee's Avatar
heavyzee
3/4" heater hose some hose clamps, and a brass or plastic hose fitting form HD or oreilly works well
Old Jul 29, 2016 | 10:46 PM
lusor's Avatar
lusor
This is what I needed to know.
To PCV install help
