MMS 396ci Dyno Results
Sep 11, 2002 | 03:34 PM
I thought I'd share the results of my new MMS motor. The car is a 2001 Z28, A4, TP4400 (locked), 4.10 gears, 17" rims, TTS headers with bullet mufflers, etc. Hoping for 134mph when I get the tranny and stall problems sorted out. My old MMS heads/cam package went 127mph!
The higher number is my new engine, the lower is my old head/cam setup.
Sep 11, 2002 | 04:18 PM
Re: MMS 396ci Dyno Results (Terry Burger)
Congrats Terry ! Those are some very impressive NA #'s ! Especially considering your running 4.10s with an Auto.
:cheers:
Jeff
Sep 11, 2002 | 04:59 PM
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Awesome numbers on your 396 all bore on an A4 with 4.10.. Looks like you have your self a 10 second naturally aspirated beast on your hands! :smash:
Congrats and good luck :cheers: !
Nitrovette
Sep 11, 2002 | 05:04 PM
From: My barber didn't know when to quit... Do you?
Re: MMS 396ci Dyno Results (Nitrovette)
Wow, very nice!! :cheers:
Sep 11, 2002 | 05:20 PM
Terry......WOW, that's well over 625 fwhp! Considering the 20% loss for the tranny and even more for the 4.10's, 10 sec runs in your near future. :cheers:
Sep 11, 2002 | 05:38 PM
Re: MMS 396ci Dyno Results (HIGHRPM)
Thanks guys! I ran 10.87@127 "all motor" before with the heads/cam setup, so I'm really hoping for 10.4x@13x range when I get it all sorted out. With the bigger engine my tranny is no longer up to the task (stock 4L60E), and my torque converter which was perfect before is now ~400rpm too loose. I should have those problems fixed in 2-3 weeks and then I'll head out for my new track times. ;)
Sep 11, 2002 | 06:16 PM
Great numbers Terry! :eek:
Sep 11, 2002 | 07:31 PM
Re: MMS 396ci Dyno Results (QuickSilver97)
:cool: :cheers:
Sep 11, 2002 | 07:33 PM
Re: MMS 396ci Dyno Results (NoMercy)
:eek: :cool: :cheers:
Sep 11, 2002 | 07:36 PM
:cheers: And if you don't mind, may I ask what is the spec of the cam you're using?
-Tuan
Sep 11, 2002 | 07:51 PM
Re: MMS 396ci Dyno Results (Tuan Le)
I have the MMS 229 v1 camshaft in it right now (229 229 112ls). I went mild on the cam for now because after I do the tranny/stall and rear end I'll be upgrading to a big solid roller setup. ;)
Sep 11, 2002 | 08:05 PM
congrats!!
BTW, Texas(Houston) says F you too :)
Sep 11, 2002 | 08:51 PM
Terry:
Long time no see......... you have a fantastic ET there.
I will be looking for you at Carlsbad this Sunday, the SRA.
Will you Be there......?
I will, if I get my car back from MMS this Friday.
Sep 11, 2002 | 08:52 PM
Thanks. What is the lift on this cam?
You are pulling great number down!
You are amazing indeed.............
regards
Bruce
Sep 11, 2002 | 09:00 PM
actually it's a 229 v2.0 cam. 229/229 .578"/.578" 114LSA
Just for the record :cheers:
Sep 11, 2002 | 09:03 PM
Cruise-In V Veteran
St. Jude Donor '09
:eek: :eek: :cool: :cheers:
Sep 11, 2002 | 09:25 PM
Re: MMS 396ci Dyno Results (binksZ06)
Just for the record
Details details. ;) Let's throw a 252/246 111ls solid roller in there soon so I can make some real power. ;)
Sep 11, 2002 | 09:35 PM
Awesome #'s
:eek: :crazy: :eek: :crazy: :eek: :crazy:
Sep 12, 2002 | 01:52 AM
How long do you think it will last before it starts to leak water/coolant like a sieve? :confused:
