Max compression pump gas
Old Jul 31, 2016 | 10:48 PM
Titan22's Avatar
Titan22
Default Max compression pump gas
I'm thinking on a build and wonder how high compression can you run on pump gas? Thinking 416cid.
Thx R
Old Aug 1, 2016 | 09:53 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
91? or 93?
I would say probably 12:1 depending on the parts and how much timing you throw at it. The tuning window will be relatively narrow, so make sure you have a skilled tuner working with you.
Good luck with your build.
Old Aug 1, 2016 | 11:52 AM
FASTFATBOY's Avatar
FASTFATBOY
I ran 12.5 to 1 in a second gen LT1 on 93 octane.
You need a really tight quench and a good bit of overlap to bleed off cylinder pressure at low speed.
Old Aug 1, 2016 | 11:56 AM
feeder82's Avatar
feeder82
If you keep the dynamic ratio at 8.5 or less you can run 91octane,
8.5 to 8.7 93 octane, with the higher static ratios, plus good tuning, and other factors. Lots of good info on the forums on how to do this.
Old Aug 2, 2016 | 07:59 AM
C5Natie's Avatar
C5Natie
I went 12.3:1 on a forged LS6 before but I eventually started using E85. Gotta be careful with timing. 91 sucks so I'd probably go 11.5 max with the right heads cam combo.
To Max compression pump gas
