98 ebcm smoking
Old Aug 2, 2016 | 09:41 AM
jimih941's Avatar
jimih941
Default 98 ebcm smoking
As the title says... last night driving home from work I noticed the abs and traction light pop on. This has happened before because my left front speed sensor has a faulty ground, so I figured it was the same thing. I pull into the garage and check the codes as usual to clear it out and notice it says no comm on the tcs portion. I go under the hood to see if something was knocked loose and notice the wiring harness at the ebcm is smoking. I unclipped it and the wiring harness clip was completely melted. So, I'm guessing the ebcm has gone bad (v model)... is it safe to put a new one on or is there a short that caused this to happen? Also, will the power brakes still work without the ebcm? This way I can still drive the car until I'm ready to shell out $1000+ for a new unit. Thanks in advance for any help or feedback!
Old Aug 2, 2016 | 05:56 PM
jimih941's Avatar
jimih941
Originally Posted by 8VETTE7
EBCM just controls the anti-lock function of the brakes. You will still have brakes and the power brake functions just no anti-lock function and hence no TC or AH. Any EBCM you get for your 99 will be "new to you" but unfortunately not new in any other sense.
Thanks for the response, I appreciate it!
Has anyone else had this problem? Can I just replace the unit or does it sound like there is a short I need to fix first before the replacement (because of the smoking).
Old Aug 2, 2016 | 09:39 PM
jcgunn's Avatar
jcgunn
These are for sale (used pulls) for big money on that auction site. It would be bad to plug a new (old) one into a shorted harness. Your best bet may be to first replace the wiring harness, they are not too pricey. Take your time and get this job right. Good luck.
To 98 ebcm smoking
