Rear Control Arm Bushing Sleeve HELP!
Old Aug 2, 2016 | 12:30 PM
pickardjj's Avatar
pickardjj
4th Gear
Default Rear Control Arm Bushing Sleeve HELP!
I am replacing my bushings with a prothane kit. The problem I am running into and it's very frustrating is the kit I purchased did not come with the steel bushing sleeves. I was under the impression that I could reuse the stock sleeves but i do not see how I can do this being the rubber is bonded too the sleeve. I cannot find where to purchase the sleeves! Can someone point me in the right direction or have any tips? I am pulling my hair out!
Thanks,
Jake
Old Aug 2, 2016 | 02:17 PM
Nasbluec5's Avatar
Nasbluec5
Torch the stock rubber out. Not sure where you live but I've just built a small fire and thrown them in it and just check back at the end of the day/morning. Then wire brush them clean. OR you can go crazy with a drill to drill the rubber out and clean it up with a razor blade. All the urethane kits I've ever done don't come with new sleeves.
Old Aug 2, 2016 | 02:42 PM
GCG's Avatar
GCG
Originally Posted by Nasbluec5
Torch the stock rubber out... ...just built a small fire and thrown them in it and just check back at the end of the day/morning. Then wire brush them clean...
Wouldn't that mess up any thermal treatment they might have?
Old Aug 2, 2016 | 02:52 PM
Nasbluec5's Avatar
Nasbluec5
Never had any issues in all the cars I've done. The sleeve is just a carrier for the bushing, not a stressed part of the suspension. Just don't build a raging bonfire and don't qelch them in water if they're super hot.
Old Aug 3, 2016 | 12:50 AM
pickardjj's Avatar
pickardjj
4th Gear
Thanks Guys!
You all answered my question. I got it done with box knife, pneumatic die grinder with scotch brite pad, and a lot of elbow grease!
Old Aug 3, 2016 | 01:01 AM
Nasbluec5's Avatar
Nasbluec5
Glad I could help! Just wanted to give you some options!
To Rear Control Arm Bushing Sleeve HELP!
