No Low beam headlights
Old Aug 8, 2016 | 11:48 AM
lougars's Avatar
lougars
Default No Low beam headlights
I have a 2003 50th anniversary corvette, my lowbeam headlights are not working but everything else works, highbeams, turn etc.
Is this problem in the switch or? I checked the fuses and all is good.
Any ideas.
Old Aug 8, 2016 | 08:07 PM
gimp's Avatar
gimp
Well, let's debug it - if you pull the headlight bulb, is there power going to the connector when you turn the lights on? If there's power, you have two burned out bulbs, which is a pretty big coincidence, but possible. If there's no power, you have to trace it back. You said you checked the fuses - is there power going to the fuses when you turn the lights on?
Old Aug 8, 2016 | 09:06 PM
lionelhutz's Avatar
lionelhutz
Go into the options in the DIC and switch the Twilight Sentinel on. Then, next time it's dark the headlights should turn on themselves. If the low beams work then it's likely the headlight switch. If they still don't work then it could be the dimmer.
To No Low beam headlights
