fuse pulled
Old Aug 8, 2016 | 06:57 PM
kg54trains's Avatar
kg54trains
Default fuse pulled
Pulled a fuse from the fuse box in the engine compartment on the Passenger side.. It was for the air bag.. Advise on the horn membrane repair was to pull the fuse and disconnect the battery prior to a attempt it to complete the repair for the HORN MEMBRANE.. Need to replace that fuse.. The fuse did not get marked for the fuse box.. Air Bag symbol shows now as a warning light / pictured symbol.. Thanks for your help
Old Aug 8, 2016 | 08:27 PM
gimp's Avatar
gimp
Are you asking where it goes, or what fuse it is, or what?
Old Aug 9, 2016 | 07:05 AM
kg54trains's Avatar
kg54trains
QUOTE=gimp;1592805331]Are you asking where it goes, or what fuse it is, or what?[/QUOTE]
the fuse itself, and the location of this in the fuse box.. I would not be asking if my wife did not move the service manual for "Safe Keeping"
Old Aug 9, 2016 | 10:51 AM
kg54trains's Avatar
kg54trains
Default Thanks for help
The fuse for the air bag is in the fuse box in the passenger footwell. Fuse #16.
If you pulled a fuse in the engine compartment fuse box, ONLY YOU know what/which one you pulled... [/QUOTE]
Thanks 8VETTE7 it was helpful...
To fuse pulled
