LED DRL problems
Old Aug 14, 2016 | 09:13 AM
tcstaples's Avatar
tcstaples
Default LED DRL problems
Installed new clear front corner lens and amber led corner bulbs along with new amber 3157 led bulbs. Neither one of the 3157 would work, ran out of time and reinstalled factory amber bulbs which work fine. Checked and rechecked wire contacts and seated the bulbs on as far as they would go to no avail. Any suggestions?
Old Aug 14, 2016 | 09:50 AM
GCG's Avatar
GCG
Two suggestions:
1) Did you try reversing the LED bulb in the socket to invert polarities?
2) You can bench test it by manually feeding power to it. That way you can verify if it's a bad bulb or a bad contact. Sometimes the 4 wires that form the bulb's contacts in its socket need to be spread out from the socket using a small screwdriver or the tip of a blade, to make sure they effectively touch the female receptacle's contacts.
Old Aug 14, 2016 | 04:17 PM
formula1nut's Avatar
formula1nut
Check the base and make sure it is the same as the factory bulb. I had exactly the same problem and the issue was that the LED base was not correct (even though it was clearly marked 3157) and while it felt like it was seated there was no contact. Mine was not a one off issue, I found other sets labeled 3157 with exactly the same incorrect base.
Old Aug 14, 2016 | 05:28 PM
tcstaples's Avatar
tcstaples
Bought another pair of 3157A led bulbs at auto parts this afternoon , plug them in, all is good. I guess Corvette Mods sent me the wrong bulbs
To LED DRL problems
