Leaky butt fix: shims?
Old Aug 14, 2016 | 12:06 PM
billla's Avatar
billla
St. Jude Donor '14
Default Leaky butt fix: shims?
The FSM notes the need to check the shim pack in the left housing and adjust as necessary, although in the "how to" threads and videos I see no mention or activity on this.
The job looks pretty straight-forward except for that check - really required?
I also see people using sealant where none is noted in the FSM - needed?
Thanks!
Old Aug 14, 2016 | 06:14 PM
6speedsteve's Avatar
6speedsteve
I just did my left side this winter when I was installing my Drop Spindles no shims on the cover, just replaced the axle seal & O-ring and used anarobic sealant on the flange where it sits on the rearend housing, also do not get any of the sealant on the O-ring. My car had just under 9,000 miles & still had the leak. Only issue I had was getting the threaded stud out & I could not get the proper torque spec when reinstalling it so I replaced it with a bolt. My left & right photos.
Old Aug 15, 2016 | 08:07 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
Thanks!
Leaky Butt Fix - depends!
To Leaky butt fix: shims?
