"Charging System Fault"??
Old Aug 29, 2016 | 06:20 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default "Charging System Fault"??
First time this has ever happened to me.....
I got in the car, to run an errand, and instead of hitting the ignition key to "on" for a couple of seconds, to bring up the fuel pressure, like I usually do, I just went right to the "start" position. The starter fumbled for a second, the "charging system fault" message flashed on the DIC for a moment, and then the car started right up.
The DIC then read 14.2-14.3 volts, as I drove the car. The volt meter agreed with this. I drove the car for about 15 minutes, and returned home. During this time, the car ran just fine. At home, I checked for codes, and there weren't any.
Maybe just a "hiccup", or the dreaded ignition switch contact issues??
TIA!
Old Aug 29, 2016 | 06:34 PM
Smoken1's Avatar
Smoken1
If it does happen to be the ignition switch contact issue. If is an easy fix
Old Aug 29, 2016 | 07:39 PM
feeder82's Avatar
feeder82
that will pop up if the battery is low, probably just a hiccup
To "Charging System Fault"??
