Pass. Window and door lock not functioning
Old Aug 29, 2016 | 11:48 PM
Kagnus's Avatar
Kagnus
Default Pass. Window and door lock not functioning
2000 61k manual
I had a conductivity issue in the connector at the door hinge. Common problem I know and I thought I had it fixed by adjusting the flanges inside the connector. I had it working until I accidentally made a small spark while fiddling with the hot side. Checked for current and still had 12v+ on the circuits. My question is what fuse or relays would interrupt power on those two circuits? Mirror and speakers work, door switch lights up but will only lock the driver side door and the window switch also lights but does not have power tosend to the motor. Right now I'm thinking I still lack adequate contact in the connector.... yeah did I solve my own problem? Power at the connector and none at the switch... right.
Old Aug 30, 2016 | 05:46 AM
Kagnus's Avatar
Kagnus
Fuse 31.
I forgot about that box.
Once again you have rescued me.
Thank you
