wheel sensor nut question
Old Sep 13, 2002 | 03:39 PM
NoRice4Me's Avatar
NoRice4Me
Default wheel sensor nut question
How tight should the little 7/16" nut threaded on the wheel sensor (to attach it on the wheel) suppose to be?
Old Sep 13, 2002 | 04:49 PM
motoracer's Avatar
motoracer
Default Re: wheel sensor nut question (NoRice4Me)
When I had my wheels done, they got it as tight as possible.
They did not have a socket to fit and had to use an adjustable wrench. It did not break. :smash:
Old Sep 13, 2002 | 06:48 PM
ACCURATE's Avatar
ACCURATE
Default Re: wheel sensor nut question (motoracer)
35 ft lbs for domestic vehicles .. per the manual .. pg 3-111 .. :yesnod:
Old Sep 13, 2002 | 07:49 PM
NoRice4Me's Avatar
NoRice4Me
Default Re: wheel sensor nut question (ACCURATE)
Thanks! I've been loosing 1 PSI per wheel every 3-4 weeks after my switch to chrome Y2Ks. Can't find a leak, even in a tub-o-water, so I've been suspecting the sensor nut must not be tight enough.
Of course, eveyone tells me 1 PSI a month is "normal", but I haven't had to add air when I had my stock rims for 5 years. And that's true for the stock 16 inchers my the Z28, too. So I just can't accept that very slow leak as "normal"... Thanks again.
Old Sep 13, 2002 | 08:09 PM
CVCVCV's Avatar
CVCVCV
I think you meant to say 35 lb/INCHES!!!!!
For goodness sake, don't use 35 ft/lbs you will snap them poor little puppies right off!
Perry :smash:
[Modified by CVCVCV, 4:09 PM 9/13/2002]
Old Sep 13, 2002 | 08:18 PM
EMDExpress's Avatar
EMDExpress
Default Re: wheel sensor nut question (CVCVCV)
I think the old style are 111 inch/lbs but you better be sure. I will check my manuals later. The old style was used on 97-2000 and are larger than the ones used now. Be sure you use NEW rubber seals everytime you take off the senor from the wheel. They can leave you stuck somewhere. :cool: :cheers: :smash: :cheers: :cool: :seeya
[Modified by EMDExpress, 7:19 PM 9/13/2002]
Old Sep 14, 2002 | 01:07 AM
ACCURATE's Avatar
ACCURATE
I stand corrected !!!
:cheers: :cheers:
To wheel sensor nut question
