Escaped the Bullet
Old Sep 6, 2016 | 12:39 PM
tentuna's Avatar
tentuna
Default Escaped the Bullet
Had the dread Service Column Lock come up today with the LMC5 previously installed, no effect, just reset and drive off as normal, call Compliance Parts (Rich ) and all you have to do is pull battery cable and the BCM will reset, boy is that easier than being stuck with the column locked out on the road. Great device and saved me a lot of hassle.
Old Sep 6, 2016 | 05:01 PM
rrwirsi's Avatar
rrwirsi
Strange process. Not in the in the LCM5 instructions. Is this a anomaly with your car per Compliance Parts?
Old Sep 6, 2016 | 05:02 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Sep 6, 2016 | 08:23 PM
FX VETTE's Avatar
FX VETTE
Old Sep 6, 2016 | 08:43 PM
MSUGTO's Avatar
MSUGTO
I always thought that the message wouldn't even come up with the LMC5 installed. Maybe you need to do the brown wire modification so that you don't get the error message.
Old Sep 6, 2016 | 09:09 PM
MSUGTO's Avatar
MSUGTO
Originally Posted by 8VETTE7
I believe that if you read the install instructions for the LMC5 on page 2 in the section titled "Optional LMC5 Modification Procedure", it states that the brown wire mod addresses the "Pull key and wait 10 seconds" message.
Yep! Installed mine yesterday, of the 5 or so starts after the install the message came up twice. Went back and did the brown wire modification, hasn't come up since.
To Escaped the Bullet
