HVAC / Climate Control Lights are out
So I have searched and read a lot of posts about the climate control being dimmed or out and the fix is to re-solder the 6 resistors or whatever they are called and that will fix the issue.
My issue is not with the climate controll.
My issue is the far left and far right side of the entire climate control module.
So Half of the passenger and half of the driver side climate does not light up (ie the red and the blue circle), the rear defrost, the off button, the mode button and the AC button also do not light up.
All of them currently work and have no issue.
My question is, is this the same issue where all I have to do is resolder the 6 things or do I actually have bulbs burnt out?
Is there any instructions on how to replace bulbs? Does a local shop such as an auto zone carry these bulbs? Are the bulbs easy to replace? If I replace them, should I or do I have to replace them all at once?
Any help would be greatly appreciated.
Hope this helps
https://www.corvetteforum.com/forums...splay-fix.html
You have light bulbs burned out. There are 14 lamps soldered on to the circuit board. At least 2 are out so replace them all.
The HVAC uses 7219 lamps behind the buttons for illumination.
Gary
Gary
