oil pressure
In any event: weird!
Anything not directly intended as a ground should never be relied on as a ground.
A stainless steel hose that crews into your engine block and into your pressure sender _should_ ground the pressure sender. However, you have to remember that often the threads are wrapped in teflon tape, or some form of dielectric grease, or there's oil in there; and the system vibrates; and so on. In other words, just because it's a metal hose doesn't mean it will necessarily ground anything properly. The only way to be sure is to *test* it. You'd need to run a continuity tester / ohmmeter from a well known ground to the sender unit. You'd need to log data as you drive. Remember, a medium-resistance ground will ground the device, but it won't do it well enough in all cases. You really want ~0 ohm resistance to ground at all times, and unless you're sure you have it...
In other words, if you want to ground something, you need to explicitly ground it with something you're sure will work as a ground. Generally that'd be a wire directly to the engine block, which is what you ended up doing!
As an electrical guy, I can tell you that cars are seriously hostile environments. You have huge temperature swings and high operating temperature, terrible weather, crap from the road, weird electrical interference inside the car itself from things like coils firing and current through the ignition wires, weird electrical interference from outside... and oh yeah, since the car doesn't have a grounded metal shell (largely fiberglass etc), you don't get a lot of protection from weird outside crap.
