Ok, I keep hearing about how the CLBs (column lock bypass modules) are somehow overloading the BCMs (body control modules) and destroying them. I'd like to hear some real world facts about this.
Urban legend? I think so. Being in an electrical eng profession, I'd like to argue just HOW a low current circuit can burn the contacts of a relay. :smash:
Few weeks ago, one of the C5 techs posted that the lower current signal from the CLB could cause the contacts in the BCM to deteriorate. Apparently, the circuit is designed to keep the contacts clean via a certain amperage from the column lock.
Hey, don't kill the messenger. I have the CLB from C5 solutions and it ain't comin' out.
[lower current signal from the CLB could cause the contacts in the BCM to deteriorate. Apparently, the circuit is designed to keep the contacts clean via a certain amperage from the column lock.]
ABSOLUTE
:bs :bs :bs
In 15 years of electronic design and repair, I've never heard of such a thing.
The bulletin from Chevrolet concerning this issue stated that the low current from the CLB to the BCM could cause the contacts in the BCM to become oxidized over time. The thrust of the issue being that if oxidized contacts in a failed BCM were determined to be caused by an aftermarket CLB, the replacement of the BCM would not be covered by the factory warranty. I've got a copy of that bulletin around here someplace. Soon as I find it I'll post the specifics.
Yes! This is one of the messages that prompted me to begin this topic thread. Also I read one tech's message that claimed that GM had some sort of TSB out about the CLBs. I'd love to read that TSB. I can't see HOW low current (or any current) can clean a set of contacts.
In my experience, HIGH current loads can cause contacts to deveelop a gassy film over a period of time causing the circuit to develop an even higher load. I talking very very high current loads here though. I'm totally open about this. I don't mean to, nor claim to be a "know it all". Teach me! I'm willing to learn.
For the record, I too have used the CLB in 2 different C5s without any known problems. Both my CLBs were made by C5Solutions.
Be sure to read the response at the bottom from COH.
Thanks a bunch for that reference. THAT is the info I wanted to read. It seems Corvettes of Houston pretty much agrees with me that this is really a non issue. So far it appears that there are no real world cases that prove that this is a valid concern.
I'd like to thank everyone that piped in on this debate as well. We need to air these issues out so that everyone is aware of all the information available and can make the most informed decisions. It's often tough to sort through it and pick out the gems but they seem to eventually surface when we work it hard. :yesnod:
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Re: CLBs destroy BCMs! (Patches)
When my new 2002 Roadster with less than 7K miles experienced the "Service Column Lock" nightmare while running (of course on a Friday night, three counties from home), the Chevy Service Manager responded by telling me the problem was fixed in 1999 and they haven't had a problem since....
This was as his Service Tech was pushing my 2002 car into the service bay for the Column Lock repair.... :crazy: :crazy:
