99 FRC Clutch Noise?
Looking for help with my 99 FRC M6 78k miles. I believe it is all stock. Recently started making some clutch noise. I would call it a metallic chatter and every once in awhile a chirp. It did this a few times recently cruising at 2k rpms and would go away when I pushed the clutch in. Now it's making the sound when I push the clutch in, in between shifts and gets louder with engine rpms, then goes away when I let off the clutch. It occasionally still makes this same noise cruising at 2k rpms.
Vid below. Thanks!
https://www.youtube.com/watch?v=Y_tr...ature=youtu.be
Vid below. Thanks!
1/4 mile/AutoX
sounds like the throw out bearing !!
Im thinking throw out bearing or pilot bearing or both. With the car sitting still in neutral I start to push the clutch in and get a chirping squealing sound. Once the clutch is fully disengaged I get the constant rattle like the sound posted in the vid. Once clutch is out/engaged the noise goes away.
Any other advice is appreciated. Im 500mi away from home in knoxville TN. Anyone know any good shops in this area? Would love to be able to make it home and do it myself but not sure it will make it.
1/4 mile/AutoX
is it highway driving ??? how much shifting will be necessary ??? shift the least possible times, and I would rather do my own at home as well, even if it had to be towed 300 miles, I don't trust anyone with my cars, never have !!!!
Im going to drive it as little as possible for now and see how it goes.
Thanks guys!
Just wanted to give an update on this. When it 1st started making the noise it didn't sound like it was going to be able to make it more then a few miles. After researching and getting a better understanding of the issue I figured I would make it home and then some.
I put a couple hundred more miles on it in the Smokey Mountains. Most of that being on the Dragons Tail and surrounding areas with minimal shifting. Then drove it home staying in 6th just about the whole time.
So I put 700ish miles on it after the noise started. Didn't really get any worse but sometimes it doesn't make a peep. I'm planning on tearing into this winter, I'll let you guys know what I find.
Nick
Nick
