windows are dead??
Old Sep 11, 2016 | 10:30 PM
rawvette's Avatar
rawvette
Default windows are dead??
both windows are down and will not go up. no relays clicking no dead fuses. the power locks work and the mirrors work also. i pull the two plugs from inside the dash just inside the door jam and everything looks ok. am i missing something. no memory seats. And thanks for added me.
1999 corvette FRC C5
Old Sep 11, 2016 | 11:25 PM
rawvette's Avatar
rawvette
Both door buttons are dead. Everything else works .
Old Sep 14, 2016 | 07:27 PM
rawvette's Avatar
rawvette
well i swapped in another switch assembly for the door, still the same problem. windows do nothing, but the locks work and the mirrors work. i did notice that the lights on the buttons were out on both switch assembly. i guess i'll try the door module next. any help is always appreciated.
Old Sep 15, 2016 | 12:50 PM
SJRick's Avatar
SJRick
I had a similar problem, but it was intermittent.
I discovered the problem, (by accident), was a break in the data cable from the window control computer module in the door to the BCM in the boot at the door hinge.
I purchased a wire harness on ebay, and the problem was repaired. It was a PITA to replace, so I would recommend buying a new one if you can. I guess I got lucky the used one was good.
Old Sep 30, 2016 | 08:59 PM
rawvette's Avatar
rawvette
well i finally found i have the same problem as you. while put the door harness back in place with the key on, i suddenly had relays click and lights on the buttons come. touch the window up and everything now works. it is in that cable. thanks for the info.
To windows are dead??
