ABS/Trac Cntrl light??
Old Sep 12, 2016 | 06:38 PM
bbuddine's Avatar
bbuddine
Default ABS/Trac Cntrl light??
So I recently just bought a used 2002 corvette with 80,000 miles on it and after about 1000 miles of driving later, the ABS/ Traction Control light came on and said "Service Vehicle Soon" on the dashboard. I pulled over into a neighborhood, turned off the car, waited 10 seconds and restarted the car and the light went away. About 2 or 3 days later, the same light came back on. So I did the same thing, turned off the car and restarted it and the light went away. I'm just curious to know if this is common on this generation of corvettes and what the problem may be and how I can fix it. If someone knows let me know!
Thanks!
-Brian
Old Sep 12, 2016 | 06:45 PM
Smoken1's Avatar
Smoken1
You need to pull the code...
File Type: pdf
Old Sep 12, 2016 | 06:51 PM
bbuddine's Avatar
bbuddine
Will do!
Thanks!
To ABS/Trac Cntrl light??
