Check ABS..Check Traction Control
Old Sep 25, 2016 | 06:25 PM
VZVette's Avatar
VZVette
Default Check ABS..Check Traction Control
I hope you can help. I received Check ABS..Check Traction Control indicators on the digital display. I checked the codes with an ABS scan tool and I received the following codes: 1232(left front wheel speed sensor open or shorted). 1233 ( right front etc...), 1234 (left rear wheel etc..) and 1235 which states: EBCM/EBTCM Internal malfunction. It's a 2000 Corvette convertible.
Can you please assist with the next step required to remedy the problem?
Old Sep 26, 2016 | 08:11 AM
VZVette's Avatar
VZVette
Thank you for your detailed response. I am new to the Forum. Your help is greatly appreciated!
