Engine rebuild suggestions
Old Oct 3, 2016 | 11:09 AM
JRHMUMBL3's Avatar
JRHMUMBL3
Default Engine rebuild suggestions
Hey guys,
So I have a 2001 Corvette Z06 with the original LS6. The number 3 cylinder got tired on me and I will be having the engine rebuilt.
I would like to ask everybody if they have any suggestions on what to do while the engine is out to make sure everything is done.
Thank you.
Current list of modifications:
TFS 220cc heads
Vindicator Camshaft 240/244 .605 .596 112+4
Yella Terra Ultra Lite Rockers
Fast 92 Intake Manifold
LS2 polished throttle body (I believe)
Dynatech long tube headers
B&B Bullets
160* thermostat.
Vengeance Racing Tuned
The vehicle made 483/430 on the Dyno before.
LIST OF ITEMS WHEN DOING REBUILD:
Diamond Pistons
Callies Rods
hone cylinders
deck surface
oil pump melling
timing chain
balance crank
crank/rod bearings
gasket set
LS7 CLUTCH/FLYWHEEL/BEARINGS
