New engine suggestions?
Old Oct 7, 2016 | 11:42 AM
Corvette_Koehler's Avatar
Corvette_Koehler
3rd Gear
Default New engine suggestions?
hello,
I have a 97 corvette with the 5.7 ls1 with 89,000. I blew the head gasket and the lifters are bad, also s knock in the bottom of the engine. What are some options as far as different engines I can put in? I plan on swapping engines myself to save the labor fees.
Thanks for the help
Old Oct 7, 2016 | 12:21 PM
grantv's Avatar
grantv
What is your goal? Used LS6?
Old Oct 7, 2016 | 01:00 PM
Corvette_Koehler
3rd Gear
That may be too expensive at the moment. I was thinking another ls1 or maybe ls3
Old Oct 7, 2016 | 03:12 PM
grantv's Avatar
grantv
Huh? Isn't an LS3 more coin than an LS6? Either way, sounds like you're decided...
Old Oct 7, 2016 | 04:06 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
http://www.vettenuts.net/ check with Marc he might have a option for you ??
Old Oct 7, 2016 | 05:57 PM
Roddy13's Avatar
Roddy13
Sounds like you mention a budget... so probably a used LS1... Otherwise go LS2 or LS3 IMO.
Old Oct 7, 2016 | 06:07 PM
v8srfun's Avatar
v8srfun
Rb26dett is a good engine
Jk
Old Oct 7, 2016 | 06:41 PM
Corvette_Koehler
3rd Gear
Decided to buy a ls1 long block and swap everything over
Old Oct 7, 2016 | 06:43 PM
Roddy13's Avatar
Roddy13
might as well P+P those heads while you are in there
To New engine suggestions?
