Code But No Numbers
Old Oct 9, 2016 | 10:10 AM
2ndvett01's Avatar
2ndvett01
Default Code But No Numbers
AO-LDCM came up but no suffix numbers. It's left door control module. Cleared code and it returned. Any suggestions?
Old Oct 9, 2016 | 10:32 AM
Chicago1's Avatar
Chicago1
If you open the door there is an accordian looking piece. Sometimes the wires inside that get jacked or pinched so try moving those around and see what happens. You can also swap the modules from one to another.
i also found this..
https://www.corvetteforum.com/forums...dow-locks.html
Old Oct 10, 2016 | 07:42 AM
3sACROWD's Avatar
3sACROWD
I'm not sure how familiar you are with retrieving codes. Don't be insulted by my question. Are you watching the codes during the diagnostic mode or just during manual mode? In diagnostic mode, it should show the code numbers for each control module. In manual mode it will show the control module then the number of codes in that module, in your case "LDCM 1 code" then you have to push the gages button to get the code to display.
Old Oct 10, 2016 | 11:41 AM
3sACROWD's Avatar
3sACROWD
What issues are you having with your left door?
Old Oct 10, 2016 | 11:47 AM
2ndvett01's Avatar
2ndvett01
No issues just the code.
Old Oct 10, 2016 | 01:43 PM
Chicago1's Avatar
Chicago1
You should have a code number. You are doing it correctly right?
Old Oct 10, 2016 | 05:09 PM
2ndvett01's Avatar
2ndvett01
Thanks. I am now.
Old Oct 10, 2016 | 06:21 PM
Chicago1's Avatar
Chicago1
So whats the code?
Old Oct 10, 2016 | 09:18 PM
2ndvett01's Avatar
2ndvett01
B2204 left window down switch fault, but never had a problem. I reset and cycled engine start/ off a few times and code hasn't returned.
To Code But No Numbers
