On two occassions on startup I got a DIC message of "Service Engine" and no powersteering. Engine fired fine. When I turned it off for 10 seconds and tried again there was no problem.
Re: Power Steering Out Momentarily on Startup (MRWHOOPPEE)
Checked the fluid and it was fine.
ON the way to work the power steering failed and the the temps starting rising so I shut it down. I took it to a shop a block away and they felt the harmonic balancer was bad--belt was not turning fast enough and the rubber part in the middle looked like it had given out.
