Magnasteer VES Question
Old Oct 12, 2016 | 07:54 PM
C5Natie's Avatar
C5Natie
Default Magnasteer VES Question
Does VES or Magnasteer work if you turn the tc off? I've felt it work in comp mode but haven't tried with tc off yet. Thanks.
Old Oct 12, 2016 | 08:13 PM
momo20's Avatar
momo20
By all accounts the Magnasteer II has been carried over into the '05 C6. It is possible the system has been updated and recalibrated, but it remains basically the same as C5.
MAGNASTEER
General motors used EVO variable-assist steering over the years. In 1996, a more sophisticated type of variable-assist power steering, developed by Delphi Saginaw Steering Systems, called "Magnasteer" was introduced on the Corvette and other GM lines.
Unlike EVO variable-assist power steering systems, Magnasteer does not use an orifice valve to reduce pressure to the steering gear. There’s no solenoid or stepper motor involved. Instead, Magnasteer uses magnets to assist or resist steering input.
The Magnasteer control valve assembly is mounted on the steering rack in the same location as a regular control valve assembly on an ordinary power rack. Inside the base of the Magnasteer unit is a large electromagnetic coil. Just above the coil is an inner and outer pole assembly with a permanent magnet in the center. Steering feel is varied by changing the strength and polarity of the magnets, which in turn, is controlled by changing the pulse width and direction of the current to the coil.
On 1996 and 1997 applications, Magnasteer has its own separate control module. But on the 1998 and newer applications, the Electronic Brake Control Module (EBCM), which also oversees the operation of the anti-lock brake system, handles the Magnasteer control function.
Control input to the Magnasteer is via the vehicle speed sensor. At zero mph, a negative current of approximately two to three amps flows to the Magnasteer coil. This causes the magnets to repel each other, which in turn allows more deflection in the torsion bar inside the spool valve assembly. This increases fluid flow through the spool valve to the steering gear for maximum power assist when it is needed most.
As vehicle speed increases, current flow to the Magnasteer coil is gradually reduced. At about 45 mph, current flow to the coil hits zero and Magnasteer has no effect on the amount of power assist (which is determined only by the torsion bar and pump flow).
Above 45 mph, the direction of current to the coil is reversed and continues to gradually increase up to a maximum of about three amps at 75 to 85 mph. Reversing the polarity of the coil causes the magnets to attract each other, which has the effect of stiffening the torsion bar. This reduces the amount of deflection in the torsion bar that normally occurs when the wheels are steered and causes an increase in steering effort for better road feel and high speed steering stability.
The Electronic Brake Traction Control Module (EBTCM) looks at input from a steering wheel position sensor to determine if more or less steering assist is needed under certain driving conditions. Oversteer is reduced by reducing assist, when excessive lateral G-forces are detected.
Compared to conventional power steering systems, Magnasteer gives the driver a broader range of power assist with a smooth transition from low to high speed. The system can be recalibrated to modify steering feel using a Tech 2 or equivalent aftermarket scan tool. There are three settings: Factory, More Firm and Less Firm.
MAGNASTEER II
In 1998, a second generation "Magnasteer MAGe" system was introduced. This version eliminates the permanent magnet, using a redesigned electromagnet that has one pole mounted on the input shaft and the other on the pinion shaft.
At low speed, there is no current flow through the electromagnetic coil. The level of steering assist depends solely on the calibration (stiffness) of the torsion bar. As speed increases, current flow to the coil is gradually increased up to a maximum of several amps to decrease assist and increase steering effort. Magnasteer MAGe uses vehicle speed as its only input, so there are no changes in steering effort during sudden steering maneuvers.
Magnasteer Servicing
Magnasteer is vulnerable to the same kinds of problems as any other power steering rack, including leaks, center wear, excessive play, or sluggishness at cold startup or with high mileage.
Magnasteer needs repair/replacement when there is:
Noticeable change in the amount of steering effort (all speeds)
Stiffer than normal steering (low speed), or lighter than normal (high speed).
Erratic steering feel at various speeds.
The Magnasteer system has a self-diagnostic capability, with one fault code: C1241 (Magnasteer Circuit Malfunction). The code sets when the module detects an OPEN or SHORT in the coil circuit. If this code sets, Magnasteer is disabled and there is no variable steering effort with vehicle speed changes.
The DTC C1241 will set a DIC warning, and can be read with a Tech 2 or equivalent scan tool. Tech 2 can also perform a Magnasteer function test. Current to the coil is varied to test for changes in steering effort, when turning the steering wheel. A road test also confirms any problems with the system. At low speed, the steering should require minimal effort and feel the same in both directions.
As speed increases, steering effort should gradually increase. If the steering feels lighter than normal at high speed and/or unusually stiff at low speed, Magnasteer isn’t working. If the steering feels stiff at all speeds, the problem may be hydraulic. Noise indicates air in the system or a bad pump valve.
Magnasteer Electronics
With electronic problems, check the electrical connection to the coil on the Magnasteer unit. Coil resistance between terminals A and B should read 1.6 to 3.1 ohms. An infinite (OPEN) reading indicates a bad coil (requires replacing the rack since the coil is not serviceable). Also check for SHORTS between both sides of the coil assembly and rack housing.
If the Magnasteer coil is within range, check the wiring between the coil and control module, and at the control module itself for continuity for grounds, shorts, and opens. Check the control module for voltage when the key is ON (Terminal F on the EBCM or EBTCM). If there is NO voltage at the module, check the module FUSE and wiring.
Separate fault codes (VSS Circuit P0500, P0501, P0502, P0503, P1501) and Check Engine Light, indicates a problem with the vehicle speed sensor circuit which provides control input to the Magnasteer.
Magnasteer Hydraulics:
The Magnasteer rack can be tested using a high pressure gauge to check pump output and the operation of the steering gear. Systems operate at about 1,500 psi (maximum), with a flow rate of 2-1/2 gallons per minute. A weak pump, bad pump valve or a restriction, can have an adverse effect on steering effort.
When inspecting the rack, check the bellows on both ends for the presence of fluid. Large amounts of fluid in either bellow means the seals are leaking and the rack needs to be replaced. Leaks around the input shaft also requires replacement.
Magnasteer Rack:
When installing a new rack, make sure the pump and hose have been completely drained before reconnecting the lines to the rack. Refill the system with new power steering fluid that meets GM service specifications #9985010 (GM part number 1050017 or equivalent). Old fluid contains abrasive particles that can damage new steering gears and pumps. Installing an in-line fluid filter can also help protect new components and prolong service life.
Always check the condition of the power steering hose. Old hoses become brittle and leak, and can deteriorate internally, releasing small flakes of rubber into the fluid that can cause problems in the pump and control valve. Replace any high mileage hoses to minimize the risk of future problems. Inspect the pump drive belt and replace as needed.
Once the system has been filled, bleed off any trapped air inside (discolored or foamy fluid indicates air bubbles). Bleeding is also necessary if the fluid level in the pump reservoir has gotten low and allowed air to enter the lines. Air can cause noisy operation as well as reduced power assist.
After filling the pump reservoir with the new fluid, raise the wheels off the ground and slowly turn the steering from lock to lock with the engine OFF. When you reach the stop at one side, wait five seconds before cranking the wheels to the opposite stop. Continue cranking the wheels back and forth 10 to 12 times while adding fluid to the reservoir as needed to keep it full. This will purge most of the air out of the system. You may have to use a special power steering pump air evacuator to purge all of the air from the system.
With the power steering pump air evacuator, cycle the steering from lock to lock every 30 seconds for approximately five minutes while maintaining 15 inches Hg of vacuum. Do not hold the steering wheel at the stops while cycling because this increases pressure. Repeat the vacuum procedure as many times as necesssary.
Old May 9, 2018 | 12:20 PM
Steve Mullen's Avatar
Steve Mullen
2nd Gear
is there any way to bypass the coils to turn off the "service steering sys" that shows up in the display' or just turn it off?
Old May 9, 2018 | 12:26 PM
Steve Mullen
2nd Gear
the car is a 1998 cadi deville i have checked all wiring i could fine for broken or burnt'i have removed the return line at the pump and ran fluid thru the sys till it got clear and made sure that there is no air
To Magnasteer VES Question
