and stop disconnecting the battery and were you drunk when you typed that?
Easy, I was Tipsy--same thing? Anyway--i know its the actuator--is it common to adjust itself and code goes away--could not find any info on that? Time for a cold one or 6-
You may have to go in and adjust it or fix it. There are a few threads on it so should be straight forward fix.
Thank you--why every time it adjusts itself and code goes away? Its when i change the battery--unless the experts know how to change battery without disc. battery??
