'03 headlight motor
Old Oct 17, 2016 | 03:26 PM
woodvette03's Avatar
woodvette03
Default '03 headlight motor
my headlight motor is making that grinding noise so i knew the gear is stripped. took out the motor to replace the gear then discovered the motor is loose on the housing. is there a way to tighten it back up or do i need to replace the whole unit at this point? it is sloppy enough that the motor worm gear does not engage with the driven gear. thanks.
