Service Traction System
Old Sep 16, 2002 | 09:13 PM
quad50's Avatar
quad50
Default Service Traction System
Don't know if I have a problem or not, but the Service Traction System came on the other day when I started the vert. It stayed on until I shut it off and restarted it. Hasn't come on since and hasn't come on when I've been driving. Is this something that happens once in awhile???
Old Sep 16, 2002 | 09:40 PM
needhlp's Avatar
needhlp
Default Re: Service Traction System (quad50)
You need the TAC module replaced.......it is $249 plus labor. I had the same exact problem, do not ignore it.......
Old Sep 17, 2002 | 02:45 AM
barryscott's Avatar
barryscott
Hey Now:
Pull your codes first and see what comes up!! :cheers: :yesnod:
Old Sep 17, 2002 | 06:31 AM
quad50's Avatar
quad50
Default Re: Service Traction System (barryscott)
Pulled the codes came up C1295 H. Not sure what that means?
Old Sep 17, 2002 | 03:34 PM
mozin's Avatar
mozin
General Motors C1295 Brake Light Switch Circuit Open
Since this is a H code for History I would only keep an eye on it.
Since you have no other codes and the DIC warning is gone I would not worry about the traction control message. I am no expert but this is what I would do.
Old Sep 17, 2002 | 09:23 PM
quad50's Avatar
quad50
Default Re: Service Traction System (MANNY)
Hey thanks! When I cancel the cruise with the brake all you have to do is breath on it and its off.
When I joined the forum everyone said all you have to do is ask. They weren't wrong. Here's to all :cheers: :cheers: :cheers:
To Service Traction System
