brake light switch removal problem
I figured it was the switch so I tried to remove the switch and it broke off at the barbs!. The threaded plastic is now stuck in the plate that holds it in. I've seen a few posts that say " you just need to pull the switch out". So i tried that. I'm praying that the bottom switch is the correct one. I noticed it has a metal barbed washer on the back side hear where the switch presses on the pedal. I have no idea how to remove the broken part now. Any suggestions?
Kyle
