starting issue?
Old Nov 1, 2016 | 09:06 PM
slider_buck's Avatar
slider_buck
Default starting issue?
2 times now my vette wouldnt start for me. i turn the key and nothing at all happens but all the gauges dropping off. i bypassed the clutch switch and replaced the theft relay. well today it did it again. i had a couple friends around so i pushed started it. if its an issue with the VATS will it still push start and fire up? its either the ignition not reading the resistor right or the starter right? this is on a 2002 manual tranny vette.
Old Nov 1, 2016 | 09:18 PM
c6miller's Avatar
c6miller
Check to see if you have any codes. Was your "security " light staying on after you started the car? Anyway, my guess is the lock cylinder or the ignition switch. They both are prone to fail.
