battery disconnected - how to redo remote?
Old Sep 17, 2002 | 09:49 AM
gmf's Avatar
gmf
Default battery disconnected - how to redo remote?
My remote control doesn't work after disconnecting the battery and I don't remember how to reset the remote. Anyone know? Thanks!
Old Sep 17, 2002 | 11:36 AM
1BAD C5's Avatar
1BAD C5
Default Re: battery disconnected - how to redo remote? (gmf)
I believe you need to press the lock and unlock buttons at the same time and hold for seven seconds. When I did this, it almost immediately reset and I was good to go.
Hope this helps,
Richard
:cool:
Old Sep 17, 2002 | 11:38 AM
Casper001's Avatar
Casper001
Default Re: battery disconnected - how to redo remote? (1BAD C5)
Yes, that should take care of reprogramming the remotes.
Old Sep 17, 2002 | 11:44 AM
gmf's Avatar
gmf
thanks! Will try it out.
Old Sep 17, 2002 | 12:06 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
If you have your manual, the one that comes with the car. It will tell you how to program the remotes. You will need to get the DIC to a certain mode then press the two buttons to program the remote. If pressing the two together works for you let me know! :yesnod:
vetterdstr :cheers:
[Modified by vetterdstr, 8:08 AM 9/17/2002]
To battery disconnected - how to redo remote?
