LS3 into C5 Corvette - P0433
Currently have P0343 high voltage on cam sensor.
We attempted to swap the A and C wiring to the sensor, and received P0342 (low voltage).
This is a brand new build - no miles. I would doubt the CAM bolts are loose.
Would an X4 CAM gear give P0343? The builder put a x24 reluctor on the crank and used an LS1 timing chain (JP5618T), and it was very clear the engine was going into a C5 Corvette.
Anyways - my mechanic spoke to ECS (flashed my PCM) and now I am shipping the PCM back to ECS as there could be a fault within the PCM?
None of my research has this being a solution... but maybe I am missing something.
Issues that I've found researching:
CAM bolts are backing out.
Bad CAM sensor
Crossed A / C wiring to CAM sensor
x4 CAM gear / need x1 CAM for LS1 PCM
Thanks all. I guess I'll have a pretty good write up after this build
ALL THE PROBLEMS!
Even without the CAM sensor hooked up - the car should run, although rough (and might take longer to start)
Theft deterrent is controlled by the BCM, not PCM - how would tuning the PCM change how the anti theft works?
Have fuel/spark/air. - Car will start up for a split second then shut off.
I also read one thread where the sensor was shimmed out .030" and it fixed the problem. That should be fairly easy to do vs some of your other options.
If you did have a short it would depend where it was, before or after the connector.
Do your wiring checks and if you don't find anything, try shimming the sensor. If you look at the troubleshooting procedure in the Diagnostic Aids section you will see that contact between the cam reluctor and sensor is one of the things to check.
"The CKP system variation learn procedure is also required when the following service procedures have been performed, regardless of whether DTC P0315 is set:
An engine replacement
A PCM replacement
A harmonic balancer replacement
A crankshaft replacement
A CKP sensor replacement
Any engine repairs which disturb the crankshaft to CKP sensor relationship"
A PCM replacement
I've already shipped off my PCM back to ECS for re-tune (again). Hopefully that helps. However my spare PCM just arrived, too bad it doesn't have a flash appropriate to the mods.
For the CAM sensor... if it were grounding, wouldn't I be getting p0343 all the time? When we swapped the A/C wires - it changed to low voltage. (This could mean it needs to be shimmed, or perhaps a 4x cam is installed)
This project is such a headache.
It could be many things, including the things you mention. Have you done any of the checks listed in the diagnostic procedure?
https://www.corvetteforum.com/forums...questions.html
Was there a reason you had the VATS deleted rather than doing a relearn?
Here is the relearn procedure in case someone else doing this swap needs the information.
Programming Theft Deterrent System Components
Important
The body control module (BCM) must be programmed with the proper RPO configurations before performing learn procedures. Refer to Body Control Module (BCM) Programming/RPO Configuration .
If replacing the BCM with a GM Service Parts Operations (SPO) replacement part, the module will learn the passkey data code immediately. The existing PCM however, must learn the new fuel continue password when the BCM is replaced.
If replacing a PCM with a GM Service Parts Operations (SPO) replacement part, after programming, these modules will learn the incoming fuel continue password immediately upon receipt of a password message. Once a password message is received, and a password is learned, a learn procedure must be performed to change this password again. A PCM which has been previously installed in another vehicle will have learned the other vehicle's fuel continue password and will require a learn procedure after programming to learn the current vehicle's password.
Conditions
Use these procedures after replacing:
BCM
PCM
10 Minute Learn Procedure
Tools Required
Tech 2
Techline terminal with current SPS (Service Programming System) software
Connect the Tech 2 to the vehicle.
Select "Request Information" under "Service Programming".
Disconnect the Tech 2 from the vehicle and connect it to a Techline terminal.
On the Techline terminal, select "Theft Module Re-Learn" under "Service Programming".
Disconnect the Tech 2 from the Techline terminal and connect it to the vehicle.
Turn ON the ignition, with the engine OFF.
Select "VTD Re-Learn" under "Service Programming".
Attempt to start the engine, then release the key to ON (vehicle will not start).
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF (the vehicle is now ready to relearn the password on the next ignition switch transition from OFF to CRANK).
Turn OFF the ignition, and wait 5 seconds.
Start the engine (the vehicle has now learned the password).
With the Tech 2 (scan tool), clear any DTCs.
30 Minute Learn Procedure
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the password on the next ignition switch transition from OFF to CRANK).
Important
The vehicle learns the password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
With a scan tool, clear any DTCs if needed (history DTCs will self clear after 100 ignition cycles).
Had no idea we needed to do this, guess I'll use it for the future!We looked at the wiring.. no issues.. we swapped to a suggested cam sensor for 05-07GTO - no change. still high/low voltage errors when we swap A/C cables.
I'm thinking we either need to shim the sensor, or it has a 4x cam wheel installed.
I'm not sure how useful this is to you but it may help someone doing this swap down the road.
http://www.ls2.com/forums/showthread...-in-an-LS1-car
Here is another good How To thread. It is for an F body but much of it would apply to a Y body car as well.
http://www.camaro5.com/forums/showthread.php?t=125123
I don't know if this is possible or not but when you have the cam sensor out, can you see if the cam gear is 1X or 4X. I think you can buy a USB boroscope to plug into a laptop or Andriod device relatively cheaply on Amazon. Vettenuts posted a link to one recently . Don't remember what thread it was. That would beat tearing it apart to see.
Here is another good How to thread. It is for an F body but much of it would apply to a Y body car as well.
I don't know if there is a spec for how close the sensor should be to the high points on the cam gear, but if there is, you can measure from the high point on the cam gear to the outside of the timing cover. with that info and a measurement on the sensor you should be able to position the sensor for ideal spacing.
Dyno tuning is scheduled for the 21st.
She is LOUD. Holy wow!
Other issues are high priority after I get it back from tuning... like my oil pressure.
Thanks for checkin in Greg, appreciate the help. will post if /when i find a resolution
