Blown or cracked cylinder
Old Nov 8, 2016 | 11:49 PM
StingrayRebel's Avatar
StingrayRebel
inspect the valve and rocker arm tips for excessive wear... do you have any pics??
Old Nov 8, 2016 | 11:56 PM
Jarame g's Avatar
Jarame g
I will have to takes pictures tomarrow and figure out how to post, but the rocker arms looked good but I'm not very knowlagable on this it's the first time I have got into a motor , what do I need to do to inspect the valves do I need to pull the springs
Old Nov 9, 2016 | 12:02 AM
StingrayRebel
just look at the tips of the valves where the retainers are and flip the rockers over and inspect the the area that makes contact with the valve tip... another thing since you probably have stock rockers, make sure the bearing caps on both sides are intact, if those caps come apart you will have needle bearings floating around in the oil pan
Old Nov 9, 2016 | 12:11 AM
Jarame g's Avatar
Jarame g
okay I'll have to check them I didn't pay attention to them when I pulled but the tips looked good
Old Nov 9, 2016 | 12:19 AM
Jarame g's Avatar
Jarame g
okay all caps are still good
Jarame g's Avatar
Jarame g
and no wear on rockers
Old Nov 9, 2016 | 12:26 AM
Jarame g's Avatar
Jarame g
What do you think could have caused those metal shavings
Old Nov 11, 2016 | 11:56 AM
Jarame g's Avatar
Jarame g
Guys it wasn't any bent pushrods or bad springs being no sounds from motor could it jumped a tooth on time chain from the downshift and over rev?
Old Nov 11, 2016 | 03:24 PM
etekberg's Avatar
etekberg
Where are the pictures???
You need to track down the metal. You could send it out for analysis.
Old Nov 11, 2016 | 05:14 PM
Jarame g's Avatar
Jarame g
I can't figure how to post pics and it was one tiny pice of metal shaving in oil around springs
Old Nov 11, 2016 | 05:16 PM
Jarame g's Avatar
Jarame g
how hard is it to pull heads?
Old Nov 11, 2016 | 05:56 PM
Jarame g's Avatar
Jarame g
okay guys I turned the car over and watched rockers and push rods they seemed to be doing what there supposed too I put everything back together and started the vette still sounds and feel flooded or miss fireing on a cylinder from a cold start you could hear a tiny ticking sound does this sound like valves?
Old Nov 11, 2016 | 06:40 PM
  #33
WildRide357's Avatar
WildRide357
It's been five days and three threads and you still haven't done a compression test or checked the pushrods???
Old Nov 11, 2016 | 06:45 PM
  #34
Jarame g's Avatar
Jarame g
push rods are good I'm going to do compression test asap haven't had time due to work and don't have tester
Old Nov 11, 2016 | 07:48 PM
  #35
WildRide357
I think the parts stores here rent them. Good luck with it! Plz post up when you figure it out!
Old Nov 12, 2016 | 12:25 AM
  #36
StingrayRebel
host the pics to photobucket and then copy the IMG code and paste into your message
Old Nov 13, 2016 | 12:17 AM
  #37
lionelhutz's Avatar
lionelhutz
You go to the user control panel and pick the pictures and albums on the left bar. You can create an album and host the pictures right on this site. Really not that hard to do.
Old Nov 13, 2016 | 05:41 PM
  #38
GCG's Avatar
GCG
I can't figure how to post pics...
If you have the pictures in your computer or phone just click on the button, navigate to the picture in your device and insert it.
