GM Tech 2 - Delete options
Nov 9, 2016 | 04:02 AM
4th Gear
Hi All,
Quick question - What all can be deleted / switched off using the GM Tech 2 scan tool on a 2000 C5 Corvette A4.
I know the F45 option is one of them but that is the only one which shows up in general search etc. would like to know all there is which one can turn off / disable from the tool.
Regards,
Wyne.
Nov 9, 2016 | 08:44 AM
Nov 9, 2016 | 09:41 AM
4th Gear
Thankyou sir! Will post there.
Cheers
Wyne.
Nov 9, 2016 | 07:26 PM
Welcome to the CF!
Nov 9, 2016 | 08:35 PM
Nov 10, 2016 | 01:06 AM
Moved to C5 Tech section.
Nov 10, 2016 | 03:15 PM
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
There's not much you're going to turn off, more like set the options for your car to work.
5 Items.
Real Time Damping RPO F45
Memory Driver Convenience AAB
Front Fog Lamps T96
HVAC Auto Temp Controls CJ2
Active Handling JL4
Nov 11, 2016 | 02:30 AM
4th Gear
Thanks K-Spaz!
Cheers
Wyne
