Need Help C5 Z06 "Reduced Engine Power"
If you have never pulled codes before here is how:
https://youtu.be/SviRjIsy9G4
OR
http://www.c5forum.com/ayc/dtcdic.php
So I had a bad battery, as I knew that I had said, but when changing our battery, I must have broken a very TINY wire that connects directly to the negative battery terminal. It did not look broken, only mashed flat in a spot. But, after CLOSE examination, I found that only the plastic insulation was holding it together. This may not Be found on the average model, as this car has Supercharger, Boost gauges, O2 sensor gauge(fuel mixture), & a few other small mods, & I believe that this wire probably is associated with one of those mods, but not certain. In any case, after fixing broken wire...VROOOM!!! Away we go!! So, just wanted to say Thank You & post my experience in case it could possibly help someone else!!
