Instrument Panel & A/C Control Lights
Old Nov 15, 2016 | 07:37 PM
Steve Clevenger's Avatar
Steve Clevenger
Default Instrument Panel & A/C Control Lights
This evening, I noted that there are lights out on the little buttons around the upper right side of the instrument panel. Two of them out. I also noticed that all of the lights for the AC controls buttons are out. I have no idea how to change these bulbs or t/s why all of these are out. Everything else seems to be burning properly. Suggestions? thanks in advance.
Steve
2005 C5
1969 Stingray
Old Nov 16, 2016 | 07:42 PM
FX VETTE's Avatar
FX VETTE
Originally Posted by Steve Clevenger
2005 C5
1969 Stingray
Steve, what year Corvette are you having trouble with?
Old Nov 16, 2016 | 08:03 PM
Steve Clevenger
Originally Posted by ae guy
steve, what year corvette are you having trouble with?
2004
Old Nov 17, 2016 | 01:54 AM
SilverC54me's Avatar
SilverC54me
The HVAC lights are soldered to the circuit board inside the unit. These can be easily replaced, there are 14 of them.
The lights behind the DIC buttons (and HUD/dimmer control) have a twist lock base on them.
Both can be replace with type 7219 lamps like the following:
https://www.mcmaster.com/#1505k414/=e7c5hm
Radio Shack if there is one in your area also caries these.
The DIC lights you would just remove the old bulb from the base along with the blue silicone cover and put that on the new bulb.
If you are in Southern California I can help with the replacement.
Gary
Old Dec 10, 2016 | 12:17 PM
oldvtr's Avatar
oldvtr
Default replacing havoc bulbs
Gary
Am not accomplished at soldering but did (finally) succeed at restoring hvac display. Now working on replacing bulbs. Question: how do i clean old solder out of holes in board so i can insert new bulb leads?
Old Dec 10, 2016 | 01:49 PM
oelarse's Avatar
oelarse
Old Dec 10, 2016 | 08:48 PM
oldvtr's Avatar
oldvtr
Default removing solder
Originally Posted by oelarse
Thanks - was using that and a rubber solder sucker bulb but could not clear holes so could not push wires of new light bulbs through. Sadly, the thinest tool I have creates over-size holes that make soldering nearly impossible.
Old Dec 13, 2016 | 10:44 AM
huesmann's Avatar
huesmann
When I replaced my bulbs I heated up the solder with the iron enough to pull the old bulbs out just by rocking them back and forth. Then I heated up whatever solder was left in the hole with the iron and reamed the hole clear with a regular old straight pin.
Old Dec 16, 2019 | 01:26 PM
hgoodwiniii's Avatar
hgoodwiniii
Hi all, I see this thread related to DIC and A/C control bulbs; Does anyone know the setup for bulbs inside the stereo? I have a few bulbs out there, as well. Thanks.
To Instrument Panel & A/C Control Lights
