paging Valvegod - need valve cover
Old Sep 18, 2002 | 02:28 AM
rwj383's Avatar
rwj383
Default paging Valvegod - need valve cover
I forget if he has a website or just the email address. either way, could someone help me out here? I need a driver side valve cover to complete my PCV mod that will eliminate oil in the intake.
Old Sep 18, 2002 | 02:36 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Re: paging Valvegod - need valve cover (rwj383)
I'm curious what you did to eliminate the problem? Got any pics????
David
Old Sep 18, 2002 | 03:04 AM
rwj383's Avatar
rwj383
Default Re: paging Valvegod - need valve cover (ScreaminDemon)
quite simply, install mini filter breathers into the grommets on the vavle covers where the PCV lines hook into. one is clearly visible on your Passenger side valve cover in your sig pic, screamin. get rid of the PCV lines, put a blank-off at the T-body and mini filters on the valve covers. voila, problem solved.
Old Sep 21, 2002 | 01:50 AM
kp's Avatar
kp
Shaun's e-mail is valvegod@aol.com
Old Sep 21, 2002 | 11:50 AM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: paging Valvegod - need valve cover (kp)
thanks
To paging Valvegod - need valve cover
