Hydraulic clutch line size
Old Nov 20, 2016 | 05:26 AM
RED 72 VETTE's Avatar
RED 72 VETTE
Default Hydraulic clutch line size
Hi I am looking at changing my clutch hydraulics in my 2004 Z06 and want to do away with the restricted lines.
My question is should I go for AN3 or AN4 clutch lines, I've got a TICK master and would also like to know what size line that has already fitted ( blue areoquip fitting )probably going to do away with the GM quick release fitting and just have a continuous line from slave to master.
I think the line from the TICK master is AN3 but if someone can confirm this.
Thanks for any info
Tony from the UK
Old Nov 21, 2016 | 12:52 PM
3sACROWD's Avatar
3sACROWD
I'm not sure what size lines are on the TICK MC. I would contact TICK directly for two reasons; 1) They will know what size line they supplied. 2) They will know if increasing the line diameter will negatively affect clutch performance / disengagement. The MC needs to have ample capacity to accommodate the additional volume requirement.
Old Nov 21, 2016 | 04:07 PM
huesmann's Avatar
huesmann
I don't think increasing the line diameter will have any detrimental effect, as the connections at the master and slave will still be the same diameter. I mean, I assume you're not increasing the diameter to like coffee can size!
Old Nov 21, 2016 | 05:05 PM
TastyBacon's Avatar
TastyBacon
I am using the stock master, but I made a -3 AN unrestricted line for mine and it works great.
Old Jul 22, 2024 | 12:57 AM
427troy's Avatar
427troy
TastyBacon, Did you ust ap the MC? How does one just thread a 3AN fitting into a non-threaded, O-ring style connection?
Old Jul 22, 2024 | 11:55 AM
TastyBacon's Avatar
TastyBacon
You can buy adapters: https://www.summitracing.com/parts/rus-640281
Old Jul 22, 2024 | 07:53 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Why?
To Hydraulic clutch line size
