Hydolocked engine disected..
Old Nov 24, 2016 | 10:19 PM
pgandy's Avatar
pgandy
Default Hydro-locked engine disected..
I decided to to post pictures of the interior of the engine and components as I was curious to see the damage. This is the engine I replaced with a nearly identical LS1 in the '04 C5.
I removed the exterior sellable/tradable components and dug into the engine.
My guess is that standing water was scooped up by the intake, bypassed the filter through a faulty previous closure (looks like a cold air intake was removed and holes patched with duct tape at some point in the past) and went right into the intake plenum and back to the No. 7 chamber snapping the connecting rod.
The engine had 114,000 miles on it. These engines are amazing. After the tow truck delivered it from the auction the old girl fired right up and limped up the driveway into the garage on 7 cylinders and breathed her last. On this day of Thanksgiving I give thanks for her 114,000 miles of service and hope that she stands as a reminder.......don't drive into standing water and don't do crappy intake patches when you remove the cold air intake and go back to stock.
Milky oil and fragments
milky oil and fragments
closeup of oil condition
collector plate
closeup of collector plate battered by connector rod
pickup tube intake
Pistons 7-5-3-1
Pistons 8-6-4-2
Pistons, number 7 lower left
Battered pistons
Block at cylinders 7 and 8, broken cylinder at 7 on right
Cylinders 7 and 8, connecting rod from 7 went thru block adjacent to 8.. see daylight thru hole
cylinder 8 with hole above
The only damaged lifter I could find.
Battered camshaft
Camshaft
Battered lobe
battered end of camshaft, explains why the camshaft sensor was damaged
camshaft sensor
Head...chambers 7-5-3-1, 7 was scrapped clean by rotating loose piston
Chamber 7 and piston 7. Piston scrapped clean compare to other pistons
damaged crank and broken connecting rod
broken rod
View of block...fragments everywhere
Cylinder 7 with piston lodged
Empty block
Old Nov 24, 2016 | 11:25 PM
SPEED750's Avatar
SPEED750
Ton of info here. How about some pics of the head gaskets.
Old Nov 24, 2016 | 11:51 PM
pgandy's Avatar
pgandy
hmmm...may have been trashed already. I'll look. As I recall, they looked pretty good but may been marred around number 7.
Old Nov 25, 2016 | 12:41 AM
What a nightmare that must have been. Thanks for posting up the pics - very informative.
Old Nov 25, 2016 | 03:02 AM
Rob 02's Avatar
Rob 02
That is a lot of damage. This is all that was wrong with mine.
Old Nov 25, 2016 | 08:21 AM
runner140*'s Avatar
runner140*
I've never seen such damage in a non-racing engine. You'd expect to see something like that at 10,000 RPM's.
Old Nov 25, 2016 | 09:14 AM
pgandy's Avatar
pgandy
Attachment 48039688
Nice! Was it running? Looks like someone tried to start it with water already in the cylinder.
Old Nov 25, 2016 | 09:19 AM
pgandy's Avatar
pgandy
I've seen this exact condition before on a Mazda 5 which has the Mazda 3 engine. Had a hole in the block and same internal damage. That one also started up and ran on 3 cylinders.
The hole in the block was what clued me to the LS1 condition when I inspected it. Tricky though, it was behind the starter, you just had to follow the sheet of oil.
Old Nov 25, 2016 | 10:36 AM
Rob 02's Avatar
Rob 02
I don't know what happened since I got it at auction. Maybe It just had a smaller sip of water than yours. There was no other damage and the cylinders didn't even need to be bored over (just honed). That is with 130K miles. I didn't trust the heads even though there was no damage. I haven't checked compression yet.
Drinking water is worse than racing. It doesn't compress and the weeniest part has to brake.
Old Nov 26, 2016 | 01:41 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Great pics. I'll try to remember not to do that.
Old Nov 26, 2016 | 09:43 PM
pgandy's Avatar
pgandy
Too late, out with the trash and picked up.
Old Nov 26, 2016 | 09:50 PM
Rob 02's Avatar
Rob 02
My heads nor head gasket look's abnormal in my case. There was no loss of cylinder pressure. The rod was clearly the weakest point.
I'm glad It was. There is light striation on my piston but thanks to the skirt coating it did not damage the cylinder wall on mine.
My crank shaft was straight as an arrow with no signs of distress. I think that is pretty amassing for a ductile Iron crank. The crank was polished and reused.
Old Nov 26, 2016 | 09:51 PM
pgandy's Avatar
pgandy
I tried to move quick on the compression check on the replacement engine once the engine was warm. The worst part was plug 7 but easier with air pump hose detached and out of the way. The biggest help was a remote starter switch attached to center peg on starter and other leg on battery. Had to use articulating needle nose to attach on starter, couldn't get my hand in there. I pulled fuel pump relay but may not be needed. Compression hose attached fairly easily using a mirror.
To Hydolocked engine disected..
