My 2004 ls1 usually runs at 220f if i keep airflow on it, 50mph+, slower or traffic it bounces around to 240(next large mark i guess). Is this typical.
Way too hot! Should be 196 on the road, 220 at the drive thru. Check for crud, plastic bags on the front of the radiator, then check for air in the cooling system.
NOT typical. Especially this time of year!!! Likely that the face of the radiator is plugged up with debris.
The C5 is a bottom breather and pulls cooling air for the radiator and AC condenser from the road level. As such it sucks up everything off the road like a vacuum cleaner and throws it against the cooling fins. With debris blocking air flow the car will run much hotter than it needs to.
Get the front of the car up on ramps or jack stands and look up into the pocket just behind the air dam and you will most likely see lots of "stuff" covering the radiator and AC condenser fins.
Best way to clean it is to remove the radiator and use a garden hose from the engine side of the radiator toward the front to wash out/remove the debris. Going the other direction simply pushes the dirt and sand pebbles deeper into the fins.
Another thing to check is the condition of the lower air dams. These do get to a point where they are so beat up (or even missing) from hitting things that they don't force enough air up into the radiator and A/C condenser.
Once you get the high temp problem solved, you should do a cooling system flush and refill. The OEM coolant is DexCool and it has about a 5-year life. If the coolant hasn't been changed in the last 4-5 years, it should be done now. Do you know if the thermostat is original? May not hurt to replace it especially if you pull the radiator.
Check the radiator hoses too. If they are the originals, it's possible that a hose is collapsing and cutting the flow of coolant.
SacCity Corvette offers a gadget to control high temps. 220 is fine for the cooling system but there is a lot of other stuff under the hood that prefers cooler temps. This system, both wired and wireless work very well. My engine heats up when climbing any incline for a while. The CoolIt brings down the temp in minutes. Good luck...
There are several things to do to get those temps down:
1. New overflow tank cap..18 psi.
2. Check all the hoses
3. Make sure your water pump is working well.
4. Check your Tstat..test and make sure it opens when you want it to.
5. Make sure your radiator is clean and check between the radiator and
your A/C.
6. Change your coolant....use DexCool and distilled water at a 50/50%
mixture.
7. Check your air dam...not missing or bent.
My Vette runs between 180 to 200 degrees this time of year and depending on traffic and outside temps. (I do live in South Florida).
I just installed that coolit gadget and it works great. I can control the high speed fans at any time to cool down my z. my z runs at 185 all day long with a stock radiator. I live in south florida where it is hot all year long. It is 85 now.
