my XS Power headers came with a triple layer gasket, I bought GM's because some said the XS were not good, the Gm ones were also triple layer. I used the XS Power ones and after three seasons no leaks. The GM went to the parts stock cabinet !!
I have done many many LT header installs on LS type engines-----I have NEVER had any leaks using th STOCK GM multi-layer SS gaskets--- even with out even looking at the exh port surfaces on the heads
Okay, cool. Thanks for the input on oem mls. Now, if at all possible, can people who use aftermarket header gaskets......and only those people.....chime in.
lol.....I did indeed see the post about the XS gaskets. Thank you very much.
I was referring to the redundant posts about the oem gaskets, and was hoping for more opinions.
