Differeces between an FRC and a "regular" C5
Old Sep 19, 2002 | 10:35 AM
MI_SS_IL's Avatar
MI_SS_IL
Default Differeces between an FRC and a "regular" C5
Any suspension tweaks? Any engine modifications? Are FRC's only available in 6 speeds? What do they weigh?
Chris
Old Sep 19, 2002 | 11:26 AM
pburant's Avatar
pburant
Default Re: Differeces between an FRC and a "regular" C5 (MI_SS_IL)
Since you seem to be talking in present tense, starting in '01, all FRC's were Z06's and vice versa. That means 6 speed (MN12), stiffer suspension and body, and lighter weight. I don't know what options were available in '99 and '00, but the body was lighter and stiffer than the other two models.
Old Sep 19, 2002 | 11:32 AM
MI_SS_IL's Avatar
MI_SS_IL
Sorry, I should have specified. I meant LS1 FRC's ... not a Z06. Any weight specs compared to a regular LS1 C5? Does anyone know the other differences?
Chris
Old Sep 19, 2002 | 11:36 AM
Casper001's Avatar
Casper001
Default Re: (MI_SS_IL)
Check out the following link, it should provide all you need.
http://www.idavette.net/facts/c5specs/index.htm
Old Sep 19, 2002 | 11:38 AM
Richin Chicago's Avatar
Richin Chicago
Chris
Read the following:
http://www.idavette.net/hib/99hdtp.htm
The 2000 came with a more extensive option list including active handling HUD e.t.c.
[Modified by Richin Chicago, 9:38 AM 9/19/2002]
Old Sep 19, 2002 | 01:25 PM
MI_SS_IL's Avatar
MI_SS_IL
Thanks, the links above are just what I was looking for.
Chris
To Differeces between an FRC and a "regular" C5
