Shifting issues with MGW Short Shifter
Old Dec 12, 2016 | 12:28 PM
StingrayRebel's Avatar
StingrayRebel
Originally Posted by TGO
You guys must be a bunch of limp wristed pansies thinking the MGW is too stiff to shift lol!
according to the corvette forum demographic we are all old fat white guys so that explains it
Old Dec 12, 2016 | 04:43 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I may be closing in on being an "old fat white guy", but I was also a high school and college wrestler, so hardly limp wristed.
Old Dec 12, 2016 | 05:04 PM
StingrayRebel
I wasn't directing that towards you or anyone else for that matter, just poking a little fun at a recent thread (not sure if you saw that one or not)... I personally don't think the hard shifting into 1st or reverse has anything to do with the mgw shifter design... I would suspect a misaligned shifter, clutch not fully disengaging, or worn synchros in the trans... when my car was stock I had problems getting into 1st and reverse and that was solved when I installed a tick clutch master cylinder, so in my case it seems like the clutch was not fully disengaging prior to the new clutch master... that still didn't solve the wot shifting problems though... the op said the shifts feel crunchy though and to me that sounds like synchros but it's hard to say over the internet
Old Dec 12, 2016 | 06:59 PM
QCVette's Avatar
QCVette
I wasn't directing that towards you or anyone else for that matter, just poking a little fun at a recent thread (not sure if you saw that one or not)......
I wasn't taking it personally and I saw the demographic thread too. However, I am getting older and I am not in nearly as good shape as I was, so I notice my conditions (and make fun of it too).
But for the MGW, I really like the nice precise shifting.
Old Dec 12, 2016 | 09:14 PM
Bossdog's Avatar
Bossdog
Mine shifted very hard and notchy. I readjusted it with the alignment tool and it was a bit better but soon worsened again. I took it to the shop and had it analyzed. Turned out my clutch was not completely disengaging, I needed a new Clutch. Mega Bucks later, it shifts VERY well, a little stiff, a bit notchy but very nice!
Hope that's not the issue.
Old Dec 13, 2016 | 05:30 AM
Swoop Dogg's Avatar
Swoop Dogg
mine is definitely "notchy" when going through the gears at first. when its warmed up, it still feels a bit notchy, but takes less effort. I too have the feeling of it "locking" me out of 1st or reverse, but I just slap it into third before first if its giving me the business. the mgw is fairly stiff compared to stock. at first it was REALLY stiff, and then it seemed to loosen up, but still stiff. I bought mine used fwiw. I haven't done the antivenom mod, but in time I may. all this talk about it being a clutch issues worries my wallet
Old Dec 13, 2016 | 11:05 AM
huesmann's Avatar
huesmann
I bought an MGW for my C5, because I really like the feel of the one I have in my Mustang, but even with the antivenom mod it just never had that same feel, so I went back to the C6 shifter.
Old Dec 14, 2016 | 12:30 PM
El original's Avatar
El original
Replace the tranny fluid....you will be pleasantly surprised. I was!!
Old Dec 14, 2016 | 12:56 PM
lionelhutz's Avatar
lionelhutz
Mine doesn't want to do into first like you describe. Everything else is fine and I've tried re-aligning the shifter without any luck. I just try 3rd to 1st or 2nd to 1st until it drops into first smoothly.
Old Dec 14, 2016 | 01:29 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
sounds like a bad 1st gear synchro !!
Old Jan 2, 2024 | 03:24 PM
corvttdude's Avatar
corvttdude
OP, Did this ever get sorted?
Old Jan 3, 2024 | 04:31 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by Pounder
it comes with a fool proof alignment tool so I guess we could count that out ??? I have one washer in mine and after three summers of use(18,000 miles) it is butter !!!
you have to make sure the clamp bolt is tight on the shifting rod !!
I have one washer in and three summers of driving and I can shift it with two fingers !! it will loosen a bit with driving. I love that with just feel I know what gear I'm in !!!
For some reason every time you post I'm reminded of this
Old Jan 3, 2024 | 09:37 AM
  #33
jfigus's Avatar
jfigus
Originally Posted by harryk387
Installed the MGW Short Shifter Flat stick in my 2004 C5Z about a month ago and while the throw was definitely shortened there still seems to be a "crunchy" feeling when going through the gears.
I did the Antivenom mod with 1 washer thinking it would fix it, but it didnt.
Sometimes going into 1st gear when I start the car in the morning or from a dead stop feels like there is something in the way or takes a couple tries to go in smoothly (for example, I push the clutch in, try to shift to 1st and it either doesn't go in at all or goes in but feels like its got some resistance/notchiness. Same goes for reverse)
I've noticed that if I press the clutch in and shift to 1st then shift out of 1st back to neutral and do that a couple times, it gets smoother each time.
Any ideas on what's causing this or how to fix it? I've searched on here and found a shifter adjustment thread, so I followed the steps on there. Took apart the MGW this morning, repositioned everything to line up better and still the same.
Would really appreciate some insight as I hate the way the shifter feels even with the MGW
It could be your clutch fluid. Have you flushed and bleed that lately? As a simple test, is it easier going into 1st gear if you pump the clutch 5 times before trying to put it into 1st? The clutch master cylinder on the C5 is notorious crap. Some people opt for the Tick master cylinder upgrade.
Old Jan 3, 2024 | 05:36 PM
  #34
spfautsch's Avatar
spfautsch
And yes, i did notice these same problems with the stock shifter, but I think it's now more noticeable because of the stiffer and shorter throw of the MGW.
I haven't read this entire thread, so forgive me if there was a similar suggestion I haven't gotten to yet, but...
Re-read what you posted here until the lightbulb goes on.
The upper shifter components aren't the only pieces between your right hand and the shift shaft that comes out of the front of the transmission. Research it if you must, but by my recollection theres:
1) the lower shifter box
2) the pinch block that clamps the shift shaft to the lower shifter box "output" shaft
3) the shift shaft itself with two crappy pinned universal joints
4) the bushings between the lower box and the torque tube
All these components can introduce slop into the system which can produce the problems you're noticing. Also, the first/second and reverse shift forks could be bent or the pads worn (internal transmission components) which would cause these symptoms.
If you want "butter" you need to address the entire system, not just the "primary input device".
In my experience, anything shorter than a C6 upper is ridiculous overkill. Going to a short-throw shifter to improve shift feel isn't going to help unless you're willing to go the extra mile and drop the driveline to pull the shift shaft and send it to Tom (TMODCUSTOMS) along with the lower box for him to work his magic.
Old Jan 4, 2024 | 09:00 AM
  #35
corvttdude's Avatar
corvttdude
@harryk387 I have had success in adjusting g the shifter to reduce this crunchiness, and I know exactly what you are referring to. As heinous as it sounds, I have adjusted the central rod that the shifter is cupped into, and I’ve also slid the rod forward and back and left and right in the pinch clamp with major success. I know it’s a terrible way to describe it, but mine feels like the shift gates are less noticeable, but the shifts are still positive. It’s almost a little gummy, which I like personally.
Old Jan 4, 2024 | 09:55 AM
  #36
jpb1978's Avatar
jpb1978
This thread is 7 years old.
Old Jan 6, 2024 | 07:16 PM
  #37
Mc556's Avatar
Mc556
This site desperately needs an archive function
Any thread not active for 60 days should lock itself. It would keep the content more relevant to changes etc.
Old Nov 15, 2024 | 04:57 PM
  #38
Midnight_rider's Avatar
Midnight_rider
This is the first thread that popped up. Two notch is a good description. It's almost like you lifted the clutch too early and the gear is half way in, so you have to pull it some more into the gear.
Ive noticed that I tend to push the Shifter to all the way to the left. If I ease off on pulling it to the left too much, it goes in straight.
It's almost like the Shifter has a tiny gap on the left and it's not aligning it correctly.
Not sure what the antivenom mod is, but other than the 1st to 2nd shift, everything is smooth. 7th gear sometimes does the same though - all the way to the right.
