HELP! No headlights
Old Sep 19, 2002 | 05:38 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default HELP! No headlights
Sometimes my headlights don't come on when I turn them on. The headlights don't light up, nor do the headlight doors open. I can turn the switch on and off a few times and the headlight doors will open and the lights are on. On some occasions I need to wait a couple of minutes before I try again and everything works fine.
So far the problem occurs only after the car has been sitting for a few hours.
ALL the other lights come on normally. The car did this once before about 2 months ago and then stated working perfectly again. Now the problem is back.
Anybody got any ideas? Comments?
Tom
Old Sep 20, 2002 | 04:56 AM
GLF's Avatar
GLF
Default Re: HELP! No headlights (TCW)
Sounds like the problem I was having with my '85 RX-7 just as I was getting ready to sell it to my dad and get the Vette. In the RX-7, I had intermittent problems with the bright switch which contained the turn signal, head light on/off, and brights. Sometimes, not often thankfully, I would be driving down the road and the headlights would go off!!! Sometimes I would try to flip on the brights, which wouldn't come on, and when I flipped back down, the low beams disappeared! And then sometimes the low beams wouldn't work at all, but the high beams would work! I felt bad driving around with my high beams on, but otherwise I had no lights. The previous solution was replacing the bright switch. But I just got tired of working on the RX-7.
So, sorry to ramble, I would possibly think that the problem is the headlight control arm/switch. I'm sure it will cost more in the Vette than my RX-7. Good luck!!! :seeya
Old Sep 20, 2002 | 08:21 PM
TCW's Avatar
TCW
Default Re: HELP! No headlights (GLF)
Thanks GLF. Anyone else have an idea?
Tom
Old Sep 20, 2002 | 10:02 PM
lotzahp's Avatar
lotzahp
well, per the service manual......there are two things that both headlights have in common: the stalk switch and the headlamp door actuator control module.
The switch supplies 12V to the module, and it controls 4 internal relays (1 pair for each lamp. This only opens/closes the lamps. It does not have anything to do with the bulbs actually coming on.
The stalk switch has separate feeds for the bulbs themselves.
So: open the hood and turn the stalk switch on. Do the lights come on even if the doors don't flip open? If so, I would guess the stalk is OK and that pesky control module is to blame.
PS: That module is located on the passenger side below the headlight housing - supposedly :)
Good luck! get back to let us know what happens.
Old Sep 20, 2002 | 10:03 PM
ProDesign's Avatar
ProDesign
Hey TCW,
I seem to be having a similar problem. My headlights sometimes take 2 or 3 tries of turning on and off to get them to pop up. However, when I turn my lights on and they dont pop up, I at least get the lights to be on which is different than you.
My dealer states it imay be either the turn signal switch or headlamp actuator control module that may have a problem, but so far they can't reproduce the problem and won't change anything until they can verify problem.
Old Sep 20, 2002 | 11:10 PM
Skyguy^^'s Avatar
Skyguy^^
Default Re: HELP! No headlights (ProDesign)
Hey TCW,
More reasons for non-pop-up headlights :eek:
Old Sep 21, 2002 | 11:06 AM
TCW's Avatar
TCW
Thanks again to everyone who has commented thus far.
ProDesign. Check out the other thread you started about this. I posted in that thread that I really doubt that your headlight switch is bad.
Since neither of my headlight bulbs come on nor do the headlight doors open, I suspect that my headlight switch is bad. I'll be checking that out later this morning.
Here's what I've discovered. If I turn on my twilight monitor option the headlights and headlight doors work perfectly EVERY time! According to the elect schematics the twilight monitor system totally bypasses the headlight switch. See why I suspect the headlight switch now? :yesnod:
I'll post later on what I find after I've taken things appart and do some real world checks.
Tom
Old Sep 21, 2002 | 07:34 PM
TCW's Avatar
TCW
OK. I'm back. It's a bad headlight switch! The reason that the switch works some times and some times it doesn't is because the resistance is varying across the switch.
The resistance is varying from 4 to 45 ohms. Even 4 ohms is to much resistance. It should be around .5 ohm or less. In a DC circuit, voltage is lost at every resistance it encounters in the circuit. (Ohm's law) The amount of voltage dropped is determined by the amount of resistance in the componet.
The high resistance of the headlight switch caused to much voltage to be lost at the headlight switch. There wasn't enough voltage left in the circuit to power up the relays for the headlamps and the headlight door motors.
I'll be ordering a new switch Monday! It seems like the problems never end on this lemon!
Tom
To HELP! No headlights
